09-19-2009, 01:10 PM | #1 |
alternator conversion
hey all
I have a '61 with a '87 350 in it, with I think a '73ish water pump. I had the original generator in there it just died so I was going to swap out the alternator and regulator from my '66 will this work ok? also my generator is on the drivers side and I am having a problem finding brackets for that side. any suggestions? thanks |
09-19-2009, 01:15 PM | #2 |
Re: alternator conversion
09-19-2009, 02:16 PM | #3 |
that would only work if you don't have power steering, I believe it takes that spot. I personally dont like to hang accessories low as it makes them harder to get to. You need to find the brackets for a factory style set up, that looks like this:
09-19-2009, 02:19 PM | #4 |
Hit the wrong button
09-19-2009, 02:52 PM | #5 |
cool thanks for the reply
I got it in with a combo of parts from both trucks in the stock location. now I have a stupid question: the round capciter looking thing on the regulator (forgot what is called) where does it hook to. I know it physicaly mounts to the fire wall but where does the wire hook to? Last edited by Dr_Spankenstein; 09-19-2009 at 02:52 PM. |
09-19-2009, 03:19 PM | #6 |
Not sure I know what you are talking about, got a picture?
09-19-2009, 03:52 PM | #7 |
no I don't have a pic. I just looked at my bros '66 and he doesn't have it so maybe it is not necessary?
the problem I am having is the alt light (dash) is on, and when I disconnect the bat truck dies there are three wire coming off the generator (black, green{f}, brown{A}) the alt harness has red(bat) yellow(R) green(F) I think I am just going to buy a new alt and do the upgrade correctly. thanks for your help though Last edited by Dr_Spankenstein; 09-19-2009 at 03:52 PM. |
09-19-2009, 08:47 PM | #8 |
One foot in front of the other
Check this out
http://www.persh.org/pickup/IdeaPage.htm |
09-20-2009, 07:52 PM | #9 |
100% gearhead
Converting to an internally regulated alternator is easy as can be and takes no time at all.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
