Old 09-19-2009, 10:42 PM   #1
Ponchodon
'63 Differentials
I am looking for info on '63 rear ends. Want to put a Richmond Power Trac posi system in my truck, but the factory stuff only lists the 8.2 inch, 10 bolt down to '64. What I am trying to find out, is the '63 any different than the '64? In my opinion, they shouldn't be, both have 6 lug wheels, etc. Anyone out there have any ideas???
Ponchodon is offline   Reply With Quote
Old 09-19-2009, 10:48 PM   #2
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Re: '63 Differentials
63-64 is the same 17 spline 12 bolt rear. You may be better off getting a 65-69 rear as it's a 30 spline but the same lenght drum to drum as the 63-64. Someone else smarter then me should chime in though. but I think I'm pretty much right!
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 09-19-2009, 10:49 PM   #3
Eagar1
I believe they changed in 64 from 17 spline to 30 spline, and they are rare, is probably why no one makes a posi for it. I would think you would have to get the axles from a 64 to use with a richmond, but I am not sure they are the same length. It may be easier to just find a factory posi axle and bolt the whole thing in, as the 30 spline units were stronger.
Eagar1 is offline   Reply With Quote
Old 09-20-2009, 12:28 AM   #4
Captainfab
60-66 Nut
Yes you are correct ruffrida2005. The '63 & '64 12 bolts (8.875 ring gear) have 17 spline axles. Starting in '65 GM switched to 30 spline axles.
I'm not familar with the Richmond Power Trac, but I would imagine it would be for 30 spline axles. If you can't or don't want to find a '65-'69 12 bolt differential, you can use your '63 housing with 30 spline replacement axles and the Richmond Power Trac.
Old 09-20-2009, 12:51 PM   #5
ruffrida2005
Man I'm getting a little better at this being right part.
Paul
