Old 09-20-2009, 08:29 PM   #1
GMC406
Professional Grade
GMC406's Avatar
Clutch bleeding issues, Help!!
Just put new slave and clutch in my 96 F-150 I-6 4x4. Started bleeding with half pedal, enough to start in gear but not shift at all. Bled and bld and bled followed by a lil more bleeding. Read somewhere the master will trap air and you have to remove it from the firewall and tip the resevior end up higher. Did this put the master back on the firewall and tried bleeding again. Shortly therafter it got worse!. Now I push the clutch pedal and it sucks itself right down to the floor! You have to pull it back and now I am getting next to nothing out of the bleeder valve since the pedal just sucks itself right down. I am out of fluid for the night, the resevoir is full and the bleeder is cracked, let it set like that overnight. What else can I do? Opinions please.
61 GMC 9' Step
Someday it will be a build http://67-72chevytrucks.com/vboard/s...=1#post3356828
67 C-30 Red Dale motorhome http://67-72chevytrucks.com/vboard/s...31#post3845531
71 GMC Street performer in the works
Waiting for warm weather
http://67-72chevytrucks.com/vboard/s...d.php?t=341946
1990 GMC Sierra GT-sold
1983 chevy 4x4-project on hold maybe sell
1969 Triuph GT 6- sold
1996 Ford I-6 5 Speed 4x4
2004 Dodge Intrepid- milage maker
1959 Ford Fairlaine, factory a/c 292Yblock- sold
1982 Honda XL500R
Always lookin for other old trucks!
GMC406 is offline   Reply With Quote
Old 09-20-2009, 09:31 PM   #2
jeffspower
Well, Whoop-dee-do!
jeffspower's Avatar
Re: Clutch bleeding issues, Help!!
Those Fords can be a pain. The best way I have found is:
bleed all the air you can get out with the bleeder. Then, pump it full stroke as fast as you can, then walk away for 1/2 hour. When you come back to it, only "twitch" the pedal repeatedly, just barely moving the master cylinders piston until you start to feel resistance. This will bring air out the top, instead of trying to push it downstream.
Pump/ walk/ twitch/ try repeatedly until you get a pedal. Sometimes the "last little bit" I will drive out- seems to help bouncing down the road.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD
'72 K20 500 Cad/TH400/NP205 SOLD
'92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver
'72 Monte Carlo... sweet low mile toy
'11 Dodge Challenger IE 392 6spd... midlife car
jeffspower is offline   Reply With Quote
Old 09-24-2009, 06:41 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
get a large syringe from a vet/farm supply and a 6" or so piece of vacuum hose. remove master cap, open bleeder (pedal up of course), and push fluid into slave. the fluid will push the air up into the master reservoir where it wants to go anyway. this works flawlessly for me. I just did a 95 Civic last week.
as a side note, when bleeding drum brakes after you install new wheel cylinders I adjust the shoes up TIGHT. this way the fluid meets a dead wall and the hydraulic system isn't trying to move the shoes. does that make sense?
68C15 is offline   Reply With Quote
