09-21-2009, 12:14 PM | #1 |
my 71 go cart build..
here are some updated pictures from this weekend. i was able to get my rotors turned down so i could run the Center line wheels with no clearance issues,as well as clean up the front end and add the blazer tank to the rear.i am running an 18/20 combo i will be installing a 350/400 in the next couple of weeks .
09-21-2009, 12:59 PM | #2 |
Old member
Re: my 71 go cart build..
Looks like your off to a good start. Keep the pictures and updates coming.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
09-21-2009, 01:14 PM | #3 | |
09-21-2009, 01:26 PM | #4 |
i was talking about the center of the rotor. the wheels fit fine with out any machine work. it's the cap that won't fit unless you turn down the center hub on the rotor. not too hard to do.
09-21-2009, 01:39 PM | #5 |
Nice. Do I spy a tubular A-arm upgrade? Now I'm feeling motivated to bust out the wire wheels and get back to work on my 71!
09-21-2009, 02:29 PM | #6 |
yes you do, that is the cross member for my 70 2wd Blazer. that is a work in progress. 4 wd to 2 wd. full Air ride set up with trailing ares in the rear.
09-21-2009, 02:39 PM | #7 |
Eat My Rust
How much did the smoothies run you?
09-21-2009, 02:55 PM | #8 |
you know i bought the wheels when they first started selling the smoothies so i got a killer deal. i think i paid just over $350.
09-21-2009, 04:18 PM | #9 |
Factory Strippers Rule!
Ortega do you have a side profile pic of your truck? I am wondering how low it is with that rear notch.
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
09-21-2009, 05:20 PM | #10 | |
Six in a row makes it go...
Did yours come with that finish? The website said polished or chrome.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
09-21-2009, 05:49 PM | #11 |
thanks for the props...i powder coated them in my garage. you can always paint them as well.
09-21-2009, 05:49 PM | #12 |
Eat My Rust
If your gonna buy them, get them polished not chrome. To powder coat you need as close to bare metal as you can get, and chrome is just one more layer to strip.
For all 4!? That's wicked! I remember that sale a long time ago, but didn't jump on it as the truck wasn't running... Last edited by texanidiot25; 09-21-2009 at 05:52 PM. |
09-21-2009, 05:56 PM | #13 |
here is a side shot with out the c-notch. then when i notched it the rear droped another 2" in the back. but if you really want your truck low just do what the guy did in the last picture. just fill it up with a bunch of cute chicks......
09-21-2009, 06:45 PM | #14 |
HaV0KSR559<~~~
love the rims
...1969_CUSTOM_1O
FLEETSIDE_LONGBED V8_THREE-FIFTY [COMPLETE-EDELBROCK] [PERFORMANCE-SERIES] [CAM_CARB_MANIFOLD] ...TURBO-400_TRANNY... |
09-21-2009, 07:14 PM | #15 |
Eat My Rust
Did you put a flat-clear coat on the wheels, or just the flat black?
Learned the hard way you do infact need a clear on the wheels. In a few months the finish will start fading, bad. |
09-22-2009, 10:42 AM | #16 |
yeah i noticed that the black powder coat is starting to fade a bit so i plan on painting over them with Flex and Flat.it has a UV inhibiter so that should do the trick. not a big deal. or i just might paint over the powder coat with the black paint that i am using for the body. check out this paint at the Kustomshop.com.. killer deals on paint.you can see that there is a little fade on the rear wheels due to the uv exposer.
09-22-2009, 10:53 AM | #17 |
Watch out for your cornhole !
You fellas need to buy your powder from somewhere else. There are good UV resistant powders out there.
09-22-2009, 05:46 PM | #18 |
i am looking into new powder. i was buying it from Eastwood tools.
ttt |
09-22-2009, 06:27 PM | #19 |
Eat My Rust
09-22-2009, 06:43 PM | #20 |
how much did you have to machine the hub? I have a set of colorado customs boulders that are gonna require the same mod & I was worried about outer bearing support.I had thrown around the idea of powder coating them black but have chickened out so far.Man those centerlines sure look sweet!
09-22-2009, 07:25 PM | #21 |
you know i can mic them to see what i took off, as for support it was not that much. there is a lot of steal there . i am sure you will not have any problem with it.
09-22-2009, 07:40 PM | #22 |
Grandpa in the rustmobile...
man thats gonna look nice
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
09-22-2009, 07:53 PM | #23 |
this is the kind of the direction i am headed in . i will be posting more as i go. here are some picture that i have borrowed for some ideas. the balck grill for sure and i am really leaning towrd the red bed....
09-23-2009, 02:31 AM | #24 |
VA72C10
Have you considered this as an option for the bed (and under hood?)
Just the bed floor And the inners
Looking for a 67-72 swb or blazer project in or around VA. |
