Old 09-21-2009, 05:29 PM   #1
kenm78
Broken Down
kenm78's Avatar
Heater Motor ??
I have a 80 C10 with a/c when i turn the ignition to the run position I hear the fan running. The heater/air condition controls are in the off position. When I turn the key off naturally the fan stops. Do I have a bad blower resistor, or bad control, or is there something else??
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 09-21-2009, 11:10 PM   #2
asphaltburner
asphaltburner's Avatar
Re: Heater Motor ??
Yo! Chevy designed the fan to run on low, at anytime the key is on, for ventilation. I rigged mine with a toggle to turn it off. Nothing wrong with your truck.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 09-21-2009, 11:43 PM   #3
joe231
joe231's Avatar
Re: Heater Motor ??
I cut the yellow wire at the blower motor resistor on my '80 (I saw the tip on here).
no more low, but I don't need no stinking low.....the silence is golden
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 09-23-2009, 05:17 PM   #4
kenm78
Broken Down
kenm78's Avatar
Re: Heater Motor ??
Thank you for the info... Next question. Why does my a/c compressor kick on when I have it on defrost mode???
kenm78
1982 Chevy 4X4
Project truck
Old 09-23-2009, 05:35 PM   #5
joe231
joe231's Avatar
Re: Heater Motor ??
Most all do.
A/C takes the moisture out of the air, so it is benefical when you use the defroster, it also helps de-fog
CHEVY ONLY
Old 09-23-2009, 05:50 PM   #6
kenm78
Broken Down
kenm78's Avatar
Re: Heater Motor ??
Thanks for the information!!! Much appreciated.
kenm78
1982 Chevy 4X4
Project truck
