Old 09-22-2009, 10:32 PM   #1
karl
karl's Avatar
Try again with pics
Anyone know if these will fit my 75 half c10. They are off a 73 454. Maybe out of a motorhome? They are listed as police package manifolds and are nodular iron. Anouther question- what is the best way to restore these?Name:  100_0970a.jpg
karl is offline   Reply With Quote
Old 09-22-2009, 11:08 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Try again with pics
I can't say for sure if they will clear on your application. I can tell you to restore them you can bead (or sand) blast them.
I really like the Eastwood brand Hi-Temp paints. They leave a nice "as cast" finish and can be sprayed or brushed.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-22-2009, 11:56 PM   #3
karl
karl's Avatar
I will be removing the smog tubes and plugging them and would like a factory look restore?
Old 09-22-2009, 11:59 PM   #4
KQQL IT
At the body shop.
KQQL IT's Avatar
They would look good with ceramic coating too
Old 09-23-2009, 12:05 AM   #5
karl
karl's Avatar
Didnt know you could ceram coat iron manifolds? The tube headers on my Chevelle are coated.
Old 09-23-2009, 12:23 AM   #6
KQQL IT
At the body shop.
KQQL IT's Avatar
Yes sir not sure on cost but ya
Old 09-23-2009, 01:11 AM   #7
79gmcc15
Gettin It One Pice At A Time
79gmcc15's Avatar
or what about sending them to TXfirefighter for a nice powder coating?
RIP ELJAY
Work In Progress 1979 GMC C1500 Trailering Special.
Getting the truck done, one piece at a time.
“You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan
“I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby
79gmcc15 is offline   Reply With Quote
Old 09-23-2009, 01:21 AM   #8
karl
karl's Avatar
What is most durable?
Old 09-23-2009, 01:45 AM   #9
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Ceramic coating is much more durable on exhaust manifolds than powdercoating.
Powder coating is baked on at around 450 - 650 degrees and the exhaust manifolds can reach temps of up to 800 degrees and burn the powdercoating right off.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 09-23-2009, 02:10 AM   #10
79gmcc15
79gmcc15's Avatar
oh, I see. thanks
RIP ELJAY
Old 09-23-2009, 08:56 AM   #11
JohnC
JohnC's Avatar
They have some powder coating that is tolerant up to around 1000 degrees now, but still wouldn't use it on the exhaust manifolds.
JohnC is offline   Reply With Quote
Old 09-23-2009, 05:44 PM   #12
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
It seems that I read somewhere that big block manifolds (older ones anyway) were all pretty much the same dimensions, except for some higher flowing Corvette manifolds that were totally different and wouldn't fit into other chassis. So if that's true, you should be all set.
Something else that is a little off topic, but if you're going to be removing the air pump tubing you could probably take a die grinder and clean up inside of the manifolds where the tubes come into them. There's probably a little bit of a restriction right there where the tube holes are. I did that on an old Chevelle I used to have.
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 09-23-2009, 11:25 PM   #13
karl
karl's Avatar
Thanks, good idea. This wont be much more than a step up from a stock 454. 8.5-1, RV cam, 049 heads, performer intake, quadjet, dual exhaust. 3.07 posi.
Old 09-23-2009, 11:40 PM   #14
karl
karl's Avatar
I found these advertised on the web for sale and had listed c10 73-87. Do they look the same to you?Name:  a63c85351f.jpg
Old 09-24-2009, 07:59 AM   #15
77gmcjoe
77gmcjoe's Avatar
Originally Posted by karl View Post
I found these advertised on the web for sale and had listed c10 73-87. Do they look the same to you?Attachment 499549
Attachment 499550
Yes, they look the same to me.
I don't know what the coating is on them, but it makes them look pretty good!
Old 09-24-2009, 06:27 PM   #16
karl
karl's Avatar
They are high nodular iron thats why they look different from the regular crusty iron. Granted mine need blasting but they have been out in the rain and heat for years and still look relatively good. Im sure they have something sprayed on. Not sure what either. Nodular iron is always the better choice.
Old 09-24-2009, 07:06 PM   #17
leddzepp
Moderator
leddzepp's Avatar
I use POR 15 hi temp exhaust manifold paint. I drive my truck daily and they still look brand new, even after 4 yrs. You can brush it on or spray it on. You can get it in cast iron finish (stock), bright aluminum, or black.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
