#426 |
Under Construction
Re: project INCREDIBLE HULK 6.2L with 6L80E
nice work Don!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#427 |
Don, no hurry and whenever possible would you mind taking a picture from directly behind the bed with the tail gate down. I just wanna an idea (view) of how fat the tubs are. thanks! Gr8 work!!!
#428 |
You must Eat Sleep Dream about how to do some of these trucks good work .D
#429 |
![]() Join Date: Mar 2007
Nice work on the wheel tubs, welding up the seam and rounding the corners really finished it off nice.
Ryan 84 ![]() My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328 |
#430 |
great build so far love what you have done, ???? for you are you going to remove the factory climb of the roof on the cab?
http://www.tandscustomcars.com/ ![]() IT"S GOT A ROOF NOW WHOO HOO!!!! ![]() 65 GTO Build (If you wanna check it out) ![]() Last edited by 68 Quad C10; 07-24-2009 at 03:48 PM. |
#431 |
Looks even better in person! the pics just dont do it justice!
#432 |
Under Construction
Any updates Don?
#433 |
ok im back with some updates... my camara broke awhile back and i just now got another camara...so here is what im working on now....
we got some bear claw style latches for the door, and i smoothed the door and door pillar....installed the latches and the striker bolt... it looks and functions 100 times better then stock form.....also got some power windows.... ![]() ![]() ![]() ![]() Last edited by 68 short step; 09-22-2009 at 10:07 PM. |
#434 |
![]() Join Date: Apr 2007
I'm Jealous!
#435 |
Lookin good.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
#436 |
VA72C10
![]() Join Date: Mar 2008
Looks good...any pictures of the inside of the door so I can see what you did with that round hump that runs around the outside of the door? Thanks. Are those powered bear claws? And have you tested them with glass in the door (additional weight)? Are you running an additional manual popper anywhere (I was told I needed to)?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#437 |
Under Construction
Looking good Don!
#438 | |
#439 |
VA72C10
Thanks for the info...looking forward to the pictures. I am going to use the newer press in style weatherstrip so I'm not sure if that will be looser or tighter than normal weatherstrip so I have a set of poppers just in case they don't open enough.
If you end up needing a set of poppers I got two accidentally so let me know and I'll sell them to you for what I paid. THey're nice aluminum adjustable ones (non-power)
#440 |
Still Learning
CRAZY SKILLS! I finally got through the whole thread. Its just amazing how far you have came from start to now. I know you have a ton of hours on this ride......any clue how much $$$ are tied up in it? That power plant alone must have cost some bucks! Keep it up fellow Okie.
#441 |
time for a little update, the rear suspension had to be removed, because we're going with a diffrent set-up, one that matches the front...so the new ECE trailing arms, and xmember were removed and sold..also here are the pics of the inside door latch as requested (hope this helps).....
#442 |
Don, the truck is starting to come along good, really like the bear claw latches, that is something that i am gonnna do to mine yet, are you shaving the handles and locks also, what kind of solenoids are you using to release the latches? THANKS James
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
#443 |
Skills you do have, nice work...
#444 |
low n' slo
![]() Join Date: Mar 2009
damn, how the hell did i miss this build. great project man, truck looks good!
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#445 |
Where at in tulsa are you picking up these fine motors?
#446 |
while the rear suspension is all apart, i took the opertunity to weld on a drain and fill port on the rear end....this has to be one (of many) dumb things ford did, make the 9" so that you must remove the wheels, brakes, axles, and thirdmember, just to change the rear end fluid...that is just dumb planning IMO...
#447 |
don't hit anything with that drain while driving, that would leave a mess... are you gonna put a guard on it?
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
#448 |
i dont think that'll be a problem.... ill have to see what its gonna look like with the new suspension, but im sure it'll be fine. if not ill make it flush
#449 |
Restoring a 68 SWB
Are you going with a 4 link on the rear now?
My Build Thread: Lucy - My 1968 SWB - Shop Truck Style North Nashville Concrete Contractor |
#450 |
Sunburst C10!!!
from the brackets he has on it im assuming hes using trailing arms
Gage 1967 C10 Shortbed Stepside |
