Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-23-2009, 09:19 PM   #1
rigon4
rigon4's Avatar
My 1/4 mile times
This was my first time done the track so dont lol to bad. will list first to last run. My pos has a 502/th400/411gears/29inch tall tires
Reaction 1.2930
60 ft 2.0051
ET @ 594 8.6549
1/8 ET 9.2699
1/8 MPH 73.17
1/4 ET 14.7139
1/4 MPH 89.64
Reaction 1.1411
60 ft 2.4379
ET @ 594 9.1651
1/8 ET 9.7898
1/8 MPH 72.02
1/4 ET 15.2599
1/4 MPH 89.44
Reaction 1.0829
60 ft 2.3151
ET @ 594 9.0891
1/8 ET 9.7079
1/8 MPH 72.72
1/4 ET 15.1779
1/4 MPH 89.35
Reaction .8839
60 ft 2.0362
ET @ 594 8.7319
1/8 ET 9.3498
1/8 MPH 72.93
1/4 ET 14.7821
1/4 MPH 89.97
Reaction 1.0251
60 ft 2.4650
ET @ 594 9.2558
1/8 ET 9.8738
1/8 MPH 72.80
1/4 ET 15.3457
1/4 MPH 89.31
1981 K-5 Blazer 2wd
1985 C-10 Short step
1988 C-10 Suburban
rigon4 is offline   Reply With Quote
Old 09-23-2009, 09:52 PM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: My 1/4 mile times
whats your set up I would think that it would run better than 90 mph @ 14.80
seems that it pulls hard in the 1/8 but leans over on the top end?? what are you using for exhaust and carb
Hottrucks is offline   Reply With Quote
Old 09-23-2009, 11:07 PM   #3
rigon4
rigon4's Avatar
the truck has stock suspension, a 750 holley and 3 inch exhaust with delta force flow master. a buddy of mine said it was the fuel lines the po has it ran in 5/16th line so he told me to run -08 lines for more than plenty fuel. he said it is nosing over way to soon. he has run that 1/4 for every when i went to tec he got mad at me for not having a helmet he said " you will run once and be done" because he thought i would run faster than a 14.00
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 09-23-2009, 11:21 PM   #4
cableguy0
i wouldnt run the truck very hard with 5/16 line. you are going to go extremely lean on the top. you need at least a 3/8's line and thats kinda small for a 502. -8 line would probably be the best way to go though not the cheapest. you could always run aluminum tubing its a ton cheaper and not too hard to run.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 09-23-2009, 11:51 PM   #5
rigon4
rigon4's Avatar
it not to bad for -8 its like $350 of what i need
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 09-24-2009, 12:27 AM   #6
mongoose
mongoose's Avatar
that's a lot of stuff..
if you go though summit it can be real cheap
i did -8 in my car, with a new fuel pump and a log for my carb it was under 200.
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 09-24-2009, 12:39 AM   #7
rigon4
rigon4's Avatar
It is 310 from jegs that for every thing pulse extra
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 09-24-2009, 08:26 AM   #8
Hottrucks
Hottrucks's Avatar
not sure what he line is coming out of the tank but converting to an eltric pump with a lug before the carb would help alot....I would run 8/10 psi for daily driving then bump it up to 10/12 for the hot laps..then if you ever want to add a wet system your half way done
I'm not sure that 750 is enough I would need to find the flow rate for your heads??? we have a 429 with headers and the 750 isn't enough above 5500...also we stack 2 air filters so we get the flow though them....the equal amounts of air in/out is how you make power then jet accorddingly
Old 09-24-2009, 12:12 PM   #9
rigon4
rigon4's Avatar
hottrucks i all ready have a holley blue pump on the truck the 502 does not have a fuel pump boss
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 09-24-2009, 12:54 PM   #10
Super73
Super73's Avatar
I don't think it's really laying over on the top.. I use this equation and it's normally fairly close. The lower nummber is better suited for a truck being they tend to be high drag and big.
1/8 mile mph * 1.22-1.25..
So:
73mph * 1.22 = 89.06
73mph * 1.23 = 89.79
73mph * 1.24 = 90.52
73mph * 1.25 = 91.25
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 09-24-2009, 07:48 PM   #11
rigon4
rigon4's Avatar
super what does that mean 1.22 number
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 09-24-2009, 10:00 PM   #12
Wild83C10
Wild83C10's Avatar
you have a fuel pressure gauge?
What are some of the other specs on the motor?
The numbers do seem weak, but really depends on the rest of the motor.
83 C10 Stepside (SOLD, it was a blast!)
383 MASS-FLO EFI/TKO II 600/3.90 Posi 10 bolt
S475 and C4 DM running, fine tuning
turbo=
Douchebag Racing: Runs Fine all the Time
Wild83C10 is offline   Reply With Quote
Old 09-25-2009, 12:33 AM   #13
rigon4
rigon4's Avatar
wild i have the pressure set at 6 psi and did not think to up it at the track and the motor is a GMPP off road 502
502 HO Tech Specs
Block Part Number: 10237292
Block Type: Cast iron with 4-bolt main caps
Bore x stroke (in): 4.47 x 4.00
Camshaft duration (@.050 in) 211 degree intake / 230 degree exhaust
Camshaft lift (in): .510 intake / .540 exhaust
Camshaft Part Number: 24502611
Camshaft type: Hydraulic roller
Compression ratio: 8.75:1
Connecting Rod Part Number: 10198922
Connecting rods Type: Forged steel, shot peened
Crankshaft Part Number: 10183723
Crankshaft Type: Forged steel
Cylinder head Part Number: 12562920
Cylinder head Type: Iron rectangular port; 118cc chambers
Displacement (cu in): 502
Engine Name: 502 HO:
Engine type: Chevy big-block V-8
Ignition timing: 36 degree total @ 3600 rpm, with vacuum advance disconnected
Maximum rpm: 5500
Piston Part Number: 12533507
Pistons Type: Forged aluminum
Recommended fuel: 92 octane
Rocker arm ratio: 1.7:1
Rocker arms Part Number: 12523976
Rocker arms Type: Stamped steel
Valve size (in): 2.19 intake / 1.88 exhaust
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 09-25-2009, 03:11 AM   #14
Rodms
Rodms's Avatar
Dang fellows we run 1/8 around here,If we go to memphis we can't run,do to specs!!!!
Built chevy tuff!
Rodms is offline   Reply With Quote
Old 09-25-2009, 06:38 AM   #15
69trk
69trk's Avatar
I have the same heads you have with alot of work done to them and they flow pretty good. It looks like to me your motor needs a turbo!!!!
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 09-25-2009, 10:28 AM   #16
rookierodbuilder
rookierodbuilder's Avatar
rigon4, i thing super is referring to the drag coefficient of the truck and how it affects trap speed.
rookierodbuilder is offline   Reply With Quote
Old 09-25-2009, 11:52 PM   #17
Super73
Super73's Avatar
It's a simple multiplier I have found that seems to be fairly close.. Take 69trk's sig numbers for instance. His 1/4mph is 115.81 and his 1/8mph is 95.18mpmh.
115.81/95.18=1.2167
Here are a few other examples.
Mine with the converter unlocked:110/90=1.2222
Reagan:151/123=1.2276
Big Jim: 141.4/116.7=1.2116
Old 09-26-2009, 12:40 AM   #18
rigon4
rigon4's Avatar
super i see what you mean
1981 K-5 Blazer 2wd
1988 C-10 Suburban
Old 09-26-2009, 09:49 AM   #19
djracer
djracer's Avatar
Super73
Mine in 1.20 on and off the hose. What do you think that means.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 09-26-2009, 04:22 PM   #20
Super73
Super73's Avatar
By my math your 1/4 mph should be closer to 127.03na and 144.75. This is only a difference of 1.20mph NA and 2.17mph on the unit.
Perhaps your converter isn't all that efficiant?
Brakes draging?
Drag Coef is worse than us some how.. The top of your bed is skinned right? Perhaps that is causing air moving under the vehicled to build up back there? Does your gate go down? Put id down next time for a back to back comparo..
But these are just thoughts.. No factual info to support.
Old 09-26-2009, 05:12 PM   #21
djracer
djracer's Avatar
10/4 my gate doesn't drop but I will have a totally new combo and convertor.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
