Old 09-24-2009, 06:15 PM   #1
texasfunk
texasfunk's Avatar
Smile fuel questions
here lately the truck has been wasting ALOT of gas, its a 355 with an RV cam, 750 double pumper, and vortec heads, it is an 87 so it hasd the in tank fuel pumps, it has a CHEAPY mrgasket fuel pressure regulator on it, and i thought turning it down id lose performance, but gain some mileage, but it seems not to change, the truck is definately slower, but wastes about the same, the fuel pressure reg says NOT for use on Fuel injection, and for that reason has no return line, i am going to buy a fuel pressure regulator that has for a return line, and im wondering if this might help with the MPG issue? it seems like it is wasting WAY more then it should being its not a big cam, and has stock gearing and a 700r4 with overdrive, it uses abt 1/2 a tank every 120 miles, which is the distance to and from school, can anyone help? tyhanx in advance
2006 GMC Sierra CCSB, 6.0 swap
2000 Chevy C3500 Crew Cab shortbed dually
1999 Chevy c2500 Crew Cab shortbed
1982 El Camino 350/350
1979 K5 2wd blazer bagged/bodied
1986 Monte Carlo SS
1991 Chevy CK SWB-67 clip and tailgate, bagged 350/700r4
1955 Chevy Bel Air
2014 Chevy Silverado ccsb
texasfunk is offline   Reply With Quote
Old 09-24-2009, 08:01 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: fuel questions
What's your fuel pressure ? You should be using a good regulator with a return line. The stock TBI pumps put out around 14-15 PSI, which needs a return line when regulating them down to the ~6 PSI that carbs usually like.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 09-24-2009, 08:15 PM   #3
texasfunk
texasfunk's Avatar
Re: fuel questions
i am not sure, it has no gauge, the fuel pressure reg has numbers on it, 1-6, and its on about 3.5
1986 Monte Carlo SS
1955 Chevy Bel Air
Old 09-24-2009, 08:16 PM   #4
slugish
Slugish
Re: fuel questions
pretty sure your carb is too big for what you have unless its really jetted down . I bet you could get a 600 cfm eldebrock or a 650 steet avenger Holley & get better mileage & not lose any power . You just need more valve lift (ie a larger cam ) for a 750 double pumper . The vortec heads help , but are not enough alone . OR more cubic inches . Get other opinions > Iam not an expert.
slugish is offline   Reply With Quote
Old 09-25-2009, 12:08 AM   #5
shrtbx
Re: fuel questions
I think the carb is a bit big also..600 cfm is ideal for that set up or even the 650 as stated above.
shrtbx is offline   Reply With Quote
Old 09-25-2009, 12:41 AM   #6
asphaltburner
asphaltburner's Avatar
Re: fuel questions
Yo! And me three!
600-650cfm is appropriate for most small blocks. They're not capable of utilizing the cfm of a larger carb without being built for race. 750cfm would be good for a BB.
FRANKENTRUCKs' fairly well beefed 350 does quite well with it's 600 Holley, as does my Camaros' nearly identical engine with it's 625cfm Carter AFB.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 09-25-2009, 12:52 AM   #7
78maliburat
Re: fuel questions
Ill swap you carbs 650 eddy
78maliburat is offline   Reply With Quote
Old 09-25-2009, 03:05 AM   #8
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: fuel questions
my truck won't even go 120 miles on a full tank
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 09-25-2009, 04:45 PM   #9
shrtbx
Re: fuel questions
a half a tank per 120 miles is really not all that bad for these trucks from all that i read here and what others get with a carb. What is that like around 15 mpg?
Old 09-27-2009, 08:40 PM   #10
texasfunk
texasfunk's Avatar
Re: fuel questions
im not too sure, i guess im just used to the bigger gas tank of my 90, and thanks for the offer, i'd be willing to trade if it were running bad, but the truck runs amazing and i have no problems whatsoever, so id rather not touch it, and out of curiousity will a better fuel pressure regulator with a return line give me a little better mpg?
1986 Monte Carlo SS
1955 Chevy Bel Air
