Old 09-25-2009, 06:02 AM   #1
Wilson_
Wilson_'s Avatar
Front Sheetmetal removal?
I will be doing a cab swap in the near future and I would like to take off the front end in one piece.
I am just trying to plan it out first so let me run this by you guys first.
truck is a 67 gmc
1. remove headlight/turn signal wiring and battery
2. remove radiator
3. unbolt rad support
4. unbolt large cab to inner fender bolt
5. remove cowl
6. unbolt fender to cab bolts
Is that it? any thing else I am missing or tips?
Northern California Group
Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby
Wilson_ is offline   Reply With Quote
Old 09-25-2009, 08:56 AM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Front Sheetmetal removal?
Hopefully someone who has done this will chime in. When I got my 72 it didnt have a front clip so I am of no good to you. Good luck.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 09-25-2009, 09:02 AM   #3
Sinister
Between Trucks...
Sinister's Avatar
I think there's a write up in the FAQ on this.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 09-25-2009, 03:26 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I've done it once but it was years ago.IIRC there are 13 bolts to remove the front clip.The ones you mentioned are the ones I remember.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-25-2009, 05:08 PM   #5
Dynomutt
Dynomutt's Avatar
Off the top of my head I'd say bumper, windshield washer lines and A/C lines if it has it and remote power steering reservoir if it has it. Oh and the strap on the D.S. inner fender that goes around the steering shaft and I think there is one ground strap on the pass side towards the front of the inner fender. You'll have to lift and slide forward at the same time so the inner fenders will come out from under the cab.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 09-25-2009, 07:34 PM   #6
70 net440
Junior Member
70 net440's Avatar
I used a cherry picker and two strong boys.
63 C10
70 Coronet R/T
67 C10
70 Dart Swinger
71 K10
70 net440 is offline   Reply With Quote
Old 09-26-2009, 12:26 AM   #7
texanidiot25
Eat My Rust
texanidiot25's Avatar
Easier to pull the whole clip, or just the fenders? I see it as less work just to pop the fenders off, no need to mess with the rad and the electrics on the core support
texanidiot25 is offline   Reply With Quote
Old 09-26-2009, 03:07 AM   #8
Wilson_
Wilson_'s Avatar
i would like to pull the front to clean up the frame and paint it.
Old 09-26-2009, 10:01 AM   #9
slategrove
slategrove's Avatar
truck is a 67 gmc
2. remove radiator
5. remove cowl
Remove windshield wiper arms and antenna
Remove cowl
Remove Bolts from fenders to cab
Remove bumper Remove wiring/battery and rediator as stated above
Get one guy on each side and one in the front, and lift off
Radiator support will lift off with the fenders, hood and grille
slategrove is offline   Reply With Quote
Old 09-26-2009, 12:44 PM   #10
barthmonster
I see it as less work to pull the clip as 1-piece vice separately due to all the alignment and shimming to get it perfect when re-installing...
Also, I looked through the FAQ pages and couldn't find a procedure, so I'll have to wing it I guess.
Radiator and/or support. Headlight wires. Wiper-cowl. Inner-fender bolts to cab bolts.
Anything else ?? It's my first time...
barthmonster is offline   Reply With Quote
Old 09-26-2009, 12:56 PM   #11
Sinister
Between Trucks...
Sinister's Avatar
Here's the FAQ write up: http://67-72chevytrucks.com/vboard/s...d.php?t=194094
He removes the hood in the write up, apparently not necessary to do so.
Beat it to fit,
Old 09-26-2009, 01:11 PM   #12
barthmonster
thank you for the link !
Federal dollars will NOT be used to print this out as a handy reference in the garage... (grin!)
Old 09-26-2009, 03:28 PM   #13
leddzepp
Moderator
leddzepp's Avatar
I am doing this soon too. I have removed the front clip from Jeeps this way, and it makes it a LOT easier going back together as one piece, and not having to shim the fenders and hood.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
