Old 09-25-2009, 12:32 PM   #26
rbeau30
rbeau30's Avatar
Re: throttle cables, where to buy?
I just got an e-mail from my grandfather, he remembers it being a rudimentary cruise control. He remembers installing them on other cars for customers back then. He said they are quite dangerous.
Robert
1971 C20 SWB Fleetside undergoing an amateur restore.
rbeau30 is offline   Reply With Quote
Old 09-27-2009, 07:29 PM   #27
wjr
I just had the same issue and what I did was robbed a cable from an old buick,jeep cj's have a similar cable but some are longer.And you may have to slit the top of pedal rod because of different plastic insert on the cables but mine is working fine.Good luck
wjr is offline   Reply With Quote
Old 09-28-2009, 03:04 AM   #28
69heavychevy
69heavychevy's Avatar
i used a universal throttle cable set-up that you can at any oreilly's or auto zone. its the mr. gasket brand i believe, not top of the line stuff but it works.
69heavychevy is offline   Reply With Quote
Old 09-28-2009, 06:02 PM   #29
RustyParts
RustyParts's Avatar
The throttle was used on some trucks that had a winch driven by a shaft off the transfer case. Showing my age now.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires
The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers!
RustyParts is offline   Reply With Quote
Old 09-28-2009, 07:04 PM   #30
texanidiot25
Eat My Rust
texanidiot25's Avatar
I used a cable from an early 70s Ford truck and a turn buckel so it's adjustable.
texanidiot25 is offline   Reply With Quote
