Old 09-26-2009, 10:14 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
Low budget electric fan
I did some junk yard crawling the other day. The fan is out of 99 jeep cherokee
Old 09-26-2009, 10:24 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Low budget electric fan
looking good.how did you wire it up?and mount it?
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 09-26-2009, 10:28 PM   #3
KQQL IT
At the body shop.
KQQL IT's Avatar
You can kind of see the tab on the shroud The fan had 3 tabs on it 2 toward the side 1 on the bottom I cut a 45 degree piece of tubing and bolted thru the shroud and simple L bracket on the bottom Its wired to switch where the tank selector should be
Old 09-26-2009, 10:40 PM   #4
3r!c84
Badass
3r!c84's Avatar
oh so it dont turn on by itself. when it hits a surten temp?
-00 Saturn 5spd
1/4:13:90
Old 09-26-2009, 10:42 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Nope i have to turn it on/off with the switch. Low budget is the key word
Old 09-26-2009, 10:44 PM   #6
3r!c84
Badass
3r!c84's Avatar
lol nice
how much was it at the junkyard
-00 Saturn 5spd
1/4:13:90
Old 09-26-2009, 10:48 PM   #7
Storm Chaser
Storm Chaser's Avatar
Sure does look like it's supposed to be there, don't it? That's the factory shroud, right?
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 09-26-2009, 10:49 PM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
lol nice
10$ and it keeps my 400 cool at 100 degree days in cali
Old 09-26-2009, 10:53 PM   #9
3r!c84
Badass
3r!c84's Avatar
thats not bad at all.
cal. heat is different from fl. heat
-00 Saturn 5spd
1/4:13:90
Old 09-26-2009, 11:49 PM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
Yep thats a factory big block shroud drilled two holes in it to mount the fan
