Old 09-28-2009, 12:31 AM   #1
hillytim69
Question Thrush Welded/Flowmaster knockoff sound?
Hi guys I have been away from the garage for a while (other projects) such as a new baby girl last week... but finally had an exhaust put on my 75 Stepside with the 383. Now can hear things a little better. I've never ran Flowmasters or chambered mufflers in the past, usually just ran Super Turbos or cheap turbo muffs. This time i thought i'd try something different and got the Thrush Welded (Flow knockoff) mufflers. I have a mild 383 10:1 compression, Summit headers into 2.5 piping then mufflers and turndowns before rear axle. I don't mind the tinny sound but is it normal to hear a bunch of pinging/rattle noise on part throttle accel? It kind of sounds like detonation but i really dont think it is. I run 91 octane non-oxygenated gas and retarded the timing a bunch by hand and it always sounds the same. Of course i have no floor mat in the cab and a couple holes but still... Do you guys think I'm hearing exhaust pulses banging around all over the place under the truck or what? I'm thinking I'm gonna put some stock manifolds and y-pipe on with a quiet muffler and see if it goes away. I really don't think its from the engine or detonation but it sounds similiar. Maybe I'll advance the timing to make it ping and testdrive to see if its a different noise. If this is what the Flowmaster/and flow knockoffs sound like I don't like it. Opinions welcome. I told my wife if this thing blows, I'll have to do a big block but I don't think thats gonna happen. With all these kids now I'll be spending most of my time behind the wheel of the Odyssey minivan.
hillytim69 is offline   Reply With Quote
Old 09-28-2009, 02:12 AM   #2
travo77
travo77's Avatar
Re: Thrush Welded/Flowmaster knockoff sound?
i have that same flow knockoff muffler with turn down before axle on my durango and it sounds like a normal muffler to me
travo77 is offline   Reply With Quote
Old 09-28-2009, 08:35 AM   #3
olblue81
olblue81's Avatar
Maybe I'm just lazy, but instead of swapping exhaust to see if the noise goes away, I'd just slip on different mufflers (swap meet, friend) and see if it goes away. If you have the room, you could even just take the turn downs off and put 2 mufflers on each side temporarily till you diagnose.
Do you have an adjustable vacuum advance on the distributor? Maybe you've got too much vacuum advance causing part throttle ping and you need to dial that back a bit.
Oh and make sure your headers aren't leaking cause that can sound like pinging if the leak is small. When I installed mine I had to run the motor to get them hot and then tighten them again to stop the leaks at the head. And the cheap headers I bought leaked at the collector so I had the muffler shop weld the transition to the header and the exhaust pipe to the transition.
Stu-
1981 GMC Sierra Classic LWB
355- original 2 bolt block, 10.2:1, vortec heads, Comp XE268 cam, built by self in 1992
700R4-2000 stall with lockup, shift kit, Corvette servo
3.07 open diff- I need a 3.73 posi!
2nd owner since 1986 - 388,000 km and counting. 100k by the first owner and the rest by me.
olblue81 is offline   Reply With Quote
Old 09-28-2009, 06:06 PM   #4
hillytim69
I'm pretty sure the Durango has Catalytic converters and/or resonators that would soften the exhaust note before it reaches the muffler. Hey Olblue81 I'll try what you said. i was already having second thoughts about the manifolds anyway. I'll get a couple cheap turbo mufflers and put them on back of the existing muffs. Also couldn't i run with the vacuum advance disconnected just to test? otherwise I do still have the adjustable one somewhere. I "fixed" my Skipwhite HEI by putting my GM module and coil and vac advance on it. I don't really know how to adjust the aftermarket adj vac. advance either, an allen wrench but which way is which??? Thanks for the ideas. I also noticed a miss on full throttle 1-2 shifts (TH-350) or when hitting the throttle hard then backing off a bit to reduce tirespin but i think the carb needs some tuning for this engine. its an edelbrock 1902 series Q-jet. I will follow up when I can.
Old 09-29-2009, 12:37 AM   #5
olblue81
olblue81's Avatar
Pulling the hose off the distributor and putting it on the air cleaner stud will make the vac advance inoperable and will help diagnose whether it is a timing issue. My Crane Cams adjustable one has instructions in my toolbox somewhere. I'll see if I can find them.
Stu-
Old 09-29-2009, 01:22 AM   #6
hillytim69
I've been researching this online tonight, I never realized there were so many different parameters in stock vacuum advance cans. I knew they all interchange but other than that I don't know what I got on there right now. I always just ran what ever I had in the past and got lucky I guess.
Old 09-29-2009, 10:41 PM   #7
Kaysenmc
Kaysenmc's Avatar
I have this same mufflers on my 87 and have the same sound.. not very happy with them, and definately not the same sound as flowmaster. They will soon be coming off for a turbo muffler or true flowmaster
87 black silverado swb, tbi 350, 700r4, 3.40 gears. 2.5 drop spindles , 2 inches off stock coils, flip kit out back. cragers with radial ta's... ongoing piddle project!
1970 Olds rallye 350, street strip 403/350 3.73 posi. Looks stock/runnin 12's!
86 K5- SOLD!
Kaysenmc is offline   Reply With Quote
Old 09-29-2009, 11:41 PM   #8
hillytim69
Yeah I crawled under there with some shoprags today and plugged the turndowns and verified the sound is indeed the mufflers. I'll soon have some thrush welded muffs for sale... Maybe they'd be ok if I ran full tailpipes but the idea is to stay lowbuck. Anyone run Summit turbo mufflers? I heard they were Dynomax super turbo blems which would be good.
Old 10-03-2009, 11:23 PM   #9
hillytim69
just got my new Summit Turbo's welded on tonight. That Terrible sound is gone and I'm happy. I can't tell what brand the Summit muffs are but they are made in USA at least. I think they are probably just regular Dynomax turbo's and not Super Turbo's. They have some numbers on them but I cant cross reference. Anyway they are quiet, almost too quiet but thats OK too and i know they'l get louder as they break in...
Old 03-20-2010, 07:48 PM   #10
munice
regular everyday normal guy
munice's Avatar
i had a tinny, rattling sound in my exhaust (had exact same thrush muffs installed) and upon tapping underneath when the truck wasnt running I found it to be a broken baffle in the pass. side muffler. i took it back the next day and they swapped it out for free. My guess was one just got dropped in the shop or something...
munice is offline   Reply With Quote
Old 03-21-2010, 08:59 AM   #11
grinch4om
dang its hot
grinch4om's Avatar
I had 2 chamber flows on my rat, loved the sound but at cruising speeds I couldn't hear the radio...found a stock 3" in and out muffler , put 2 on and it sounds good but real quiet at speed...if I just cruised the truck, flows all the way but since I have to drive it and I MUST have radio...these work great. if anyone wants the part number, I can get it for you
grinch4om is offline   Reply With Quote
Old 03-21-2010, 09:17 AM   #12
grinch4om
dang its hot
grinch4om's Avatar
maremont...103211...44.99 at the zone fits a 93 C-3500 diesel
Old 03-21-2010, 09:56 AM   #13
USSkoval
I have the "Force" mufflers on my Suburban and it's the same deal. They look like a Flowmaster, but the sound is way off. However, after about a year of use, the sound started to change for the better and I like how they sound now. Still different from a Flowmaster though.
USSkoval is offline   Reply With Quote
