Old 09-28-2009, 02:03 AM   #1
shaneo2112RUSH
Junior Member
shaneo2112RUSH's Avatar
Exclamation Spindle Identification
Is there a way to check the numbers on a spindle to see what year it's from??
i bought a whole frontend with disk brakes a few years back from a member on here and forgot what year it came off of.
im looking to replace the bearings, rotors, calipers, hardware but i need the year to get the correct parts for it. it does have a 5 x 4 3/4 bolt pattern 12" rotor and the thickness of the rotor is 1 1/4". if that helps any!! also how do you check to see if its a heavy duty setup?
thanks
1968 LWB C10 "Project LADY EYE SORE" (She is my baby and sent me to the hospital 3 times for eye injuries lol) who said love hurts??
shaneo2112RUSH is offline   Reply With Quote
Old 09-28-2009, 07:51 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Spindal Identification
It's not a 5x5 pattern?
Got any pics?
If it has rubber bushings on the a-arms,... it's at least a '73-up version.
Keith
Convert to disc brakes.
Old 09-28-2009, 07:58 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Spindle Identification
Originally Posted by shaneo2112RUSH View Post
..... it does have a 5 x 4 3/4 bolt pattern 12" rotor and the thickness of the rotor is 1 1/4". if that helps any!! also how do you check to see if its a heavy duty setup?
If it's a 12" x 1 1/4" it is the HD rotor/caliper. It's going to be 82 up.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-29-2009, 04:39 AM   #4
shaneo2112RUSH
Junior Member
went and took some pictures and remeasured just to clarify
the bolt pattern is 5 x 4 3/4" , rotor Dia. is at 11 7/8" and thickness is 1 1/4
as far as the bushing goes the spindles were on 67 72 style a-arms so im wondering if these were PO swap to disk brakes from oem drumbrakes
just wished i knew what the bearing numbers were. the old ones have no markings on them!!
Name:  bolt pattern (642 x 385).jpg
Name:  rotor Dia (642 x 385).jpg
Name:  rotor thick (642 x 385).jpg
Name:  spindle2 (642 x 385).jpg
Name:  spindle (642 x 385).jpg
Old 09-29-2009, 05:54 AM   #5
lolife99
lolife99's Avatar
That's a 5x5 rotor. You are measuring it incorrectly. (It's the diameter of the bolt circle)
It's the standard HD 1-1/4" rotor.
Standard non-drop spindle.
I would use 1973 as the "year" when purchasing parts.
They seem to be a little cheaper than the 2-year only, 71-72 parts.
Keith
Old 09-30-2009, 05:28 AM   #6
shaneo2112RUSH
Junior Member
That's a 5x5 rotor. You are measuring it in correctly. (It's the diameter of the bolt circle)
Ok now i see what i did wrong!! you measure center of one stud to the O.D. or back of the other. Name:  5lug.jpg
Size:  9.6 KB thanks for correcting me
thanks to all for your input!! i'll let you all know how it goes at the parts store!!!
