Old 09-30-2009, 02:38 PM   #1
onequickchevy
onequickchevy's Avatar
Steering Column for my '63
What is my best junkyard choice for replacing the clapped out column in my project truck? It does not have to be column shift, as I use a B&M mounted on the floor. Just looking for suggestions.
onequickchevy is offline   Reply With Quote
Old 09-30-2009, 02:52 PM   #2
71stub
71stub's Avatar
Re: Steering Column for my '63
I like the looks of the 67-72 columns. They also don't have the ignition switch on the column. Not sure on how well they fit in 60-66 trucks but I use them in hot rods all the time. I dont like how the bulky 73-87 columns look with the ignition switch and how much larger diameter they are.
1971 Cheyenne Short Fleet - 468BB/TH400, Tilt, Tach, PS, PB
1967 Custom Short Fleet - 327/4spd
71stub is offline   Reply With Quote
Old 09-30-2009, 04:20 PM   #3
onequickchevy
Yeah, a buddy of mine has a 91 suburban he uses for "storage" out in the woods on his property i am getting parts off of ( southern comfort seat like new ! ) , and the column has a ton of stuff I don't need or want on it.
Old 09-30-2009, 04:58 PM   #4
monolith
Zero Albedo
monolith's Avatar
I thought my column was shot on my 66 GMC. Turns out all I needed was an upper bearing- 16 bucks at the Truck Shop in Orange, Ca.
Pulled the wheel, put the bearing in and it's tight again.
You may not need to replace the whole column, They're very rebuildable.
Baz
"Deserve's got nothin' to do with it."
66 GMC 1500 wideside longbed 250 4spd "Project Rekker"http://67-72chevytrucks.com/vboard/s...d.php?t=467467
65 GMC 1Ton Panelhttp://67-72chevytrucks.com/vboard/s...32#post4794432
65 Chevy Panel (former U.S.Navy truck)
64 Chevy Suburban Carryall 4x4http://67-72chevytrucks.com/vboard/s...d.php?t=358348
64 GMC 1000 wideside longbed 305 4spdhttp://67-72chevytrucks.com/vboard/s....php?p=3600890(Rip- parts truck now)
68 Dodge Charger
monolith is offline   Reply With Quote
Old 09-30-2009, 05:27 PM   #5
onequickchevy
My issue is more with the splines and threads. The wheel is actually loose on the splines, even though the spline count is correct. Almost as if someone tried to put the wrong wheel on it and ran it that way for a while. The threads are all but stripped to. I guess a trip to the salvage yard is in order. We have some good ones fairly close by. I may have to do a little cutting and welding, but no big deal, i'm used to doing that!
