10-01-2009, 04:43 PM | #1 |
air valve line installation
Im at the piont now where I need to set up my valves. (8 of them) so how exactly do these things work? I mean how do I set up the air lines for them? I get how the fills work but Im seeing on other peoples threads how they have 2 or even for connected with T pipe. I guess I dont really understand how these valves work together. can some one help me out or send my a link to plumb these?
thanks Heres my set up 1 compressor 1 tank with 8 ports 8 valves 5, 3 way switches for fbss and drop 2 two needle guages which reminds me where do I put the "t"s for the guages to read properly on each bag? before or after the fill valve? 3/8 line all the way around
1967custom Last edited by michael bustamante; 10-01-2009 at 04:53 PM. Reason: cuz I dont know how to type good |
10-01-2009, 05:19 PM | #2 |
AIRBAGPARTS.COM
Re: air valve line installation
Your gauge line goes between your fill and dump valves for each bag.
10-01-2009, 05:20 PM | #3 |
AIRBAGPARTS.COM
Also, I do have a diagram somewhere. I will try to find it and post it up for you.
10-01-2009, 07:52 PM | #4 |
thank you man I d REALLY appreciate it. Also can you pm me a price for 2 3/8 valves shipped to NM. if you cant Ill go on your web site again
1967custom |
10-02-2009, 12:44 PM | #5 |
got your quote man thank you and Ill let you know. Ill be ordering these as soon as I get back from vacation, any luck on that diagram yet?
1967custom |
10-02-2009, 03:21 PM | #6 |
Epoxy Primer Friendly
[IMG]http://www.*****************/files/how_to/wire-diagrams/8valve.gif[/IMG]
[IMG]http://www.*****************/files/how_to/wire-diagrams/valveassembly.gif[/IMG] Last edited by camaro__thunder; 10-02-2009 at 03:22 PM. |
10-02-2009, 03:42 PM | #7 |
thats what I needed man thank you. one more thing, I noticed these valves have in and out. now for the dumps, which side does the air come out of? I have seem them mounted where the inlet is not the side that the 4 way is mounted to
1967custom |
10-02-2009, 05:39 PM | #8 |
AIRBAGPARTS.COM
All valves should have an arrow or some sort of marking that show which way the air flows.
10-02-2009, 05:43 PM | #9 |
they do but ive seen where the outlet side was mounted to the four way on the dump valves. is that right? I would think the it needs to be mounted inlet side to the 4 way for both lift and dump valves
1967custom |
10-03-2009, 12:01 PM | #10 |
ha!!! I finally figured it out!!!. thanks for your haelp and for the diagram. I appreciate it.
jason: Ill be contacting suicidedoors for them valves when I get back from cincinnati. thanks again
1967custom |
