Old 10-02-2009, 07:41 AM   #1
Kim57
Kim57's Avatar
Need Another Measurement
Hey guys
If one of you has a chance can you measure how tall the tabs that the core support sets on are.
This is for a 55-59.
Thanks.
Kim
Kim57 is offline   Reply With Quote
Old 10-02-2009, 05:06 PM   #2
OrrieG
OrrieG's Avatar
Re: Need Another Measurement
If you mean the flat bracket the core sits on mine is 1-3/8" at the firewall side, 1-11/16" at the bumper side. At the center where radiator sits it is just a little shy of 1-5/8". The frame slopes down towards the front at that location.
Old 10-02-2009, 05:17 PM   #3
Kim57
Kim57's Avatar
That's the one I needed.
Thanks OrrieG.
Kim
Old 10-02-2009, 05:46 PM   #4
OrrieG
OrrieG's Avatar
Thanks OrrieG.
Kim
Dims I gave are from top of frame rail.
Old 10-02-2009, 07:37 PM   #5
blackdiesel
blackdiesel's Avatar
The v-8 bracket is different from the I-6. There is a exrta piece of steet metal on the v-8 that moves core suport back, thus making it shortter. You need to get that messurement off a truck that has the suport in the spot that your putting yours in.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 10-02-2009, 08:10 PM   #6
OrrieG
OrrieG's Avatar
Mine was originally a 6 cylinder truck
Old 10-02-2009, 08:53 PM   #7
dwcsr
Hollister Road Co.
dwcsr's Avatar
55-57 is different than 58-59
Old 10-02-2009, 11:04 PM   #8
Kim57
Kim57's Avatar
My frame has a chevelle clip on it and the core support is all the way forward.
I am making my own tabs and just needed to know how tall the originals were.
Thanks for all the info guys.
Kim
Old 10-03-2009, 08:17 AM   #9
blackdiesel
OOO... then you will have to do like I did, and hange the finders on the cab, then hold the core suport where it gos on the inter fenders to get your messurement.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 10-03-2009, 10:44 AM   #10
Kim57
Kim57's Avatar
Here's what I did to the front of my frame to mount the core. I just need to make the tabs to set it on and be able to adjust it.
Kim
Old 10-03-2009, 11:25 AM   #11
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Kim,
I have a Camaro clip, my tab is 1 3/8" on the flat side, 1 3/8 on the vert at an angle and 2 1/4 on the top where the radiator sit.
Now looking down at the tab, flat size where the rivets are is 2 3/4" and the top is 2" wide.
Hope that heleps.
Tri5
Tri5Nerd is offline   Reply With Quote
Old 10-03-2009, 01:20 PM   #12
Kim57
Kim57's Avatar
Originally Posted by Tri5Nerd View Post
Kim,
Hope that heleps.
Tri5
Thanks Tri5
That also helps. I should be able to do what I need now.
Kim
Old 10-03-2009, 02:16 PM   #13
OrrieG
OrrieG's Avatar
I pulled my Factory Assy Manual and here are the critical dimenisons you need.
The radiator support is in the same location for six and v8s. The radiator on v8s is set closer to the firewall with offset metal brackets.
The center of the support bracket is 47.50 inches from the center of the front cab mount bolt hole. the top of the bracket is .22 inches below the top of the level portion of the frame.
Old 10-03-2009, 07:08 PM   #14
blackdiesel
Are you look at the 58-59 book? the 55 -57 is is a different spot about 4" closer to the fire wall on the v-8.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 10-03-2009, 11:36 PM   #15
OrrieG
OrrieG's Avatar
My book is titled 55-59. My frame measurements match those I posted. I did find in the V8 RPO section that it appears the mounts are father towards the firewall, but there are not any dimensions. It looks like they were set by the sheet metal extension and maybe drilled on the assy line?
