Old 09-29-2009, 08:54 PM   #1
10.5stang
What are the difference in 67-72
What is the difference in a 67 to 72 frame? Any help will be great! Thanks
67 SWB in the works........ still working!
72 GMC SWB bought finished from original owner.
71 Chevrolet SWB
10.5stang is offline   Reply With Quote
Old 09-29-2009, 09:11 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: What are the difference in 67-72
The only thing that I know of is that the '67 frame does not have the dimple where the steering box is mounted.
The 1/2 ton and 3/4 ton frames are slightly different in the height of the rear cab mount on the frame and the 3/4 frame has extra bracing on the cross member where the trailing arms mount and usually the trailing arms are a little beefier.
Danny
Edit:
No GMC frames are not the same in most cases because most GMCs had leaf springs instead of coil springs like the Chevys, but they can be made to work.
Here are the pictures the first one is of the 67 frame with no dimple for the steering gear.
The second one is of the 68-72 frames with the dimple.
The third one is of the 1/2 ton rear cab mount.
The fourth one is of the 3/4 ton rear cab mount.
The fifth is of the 3/4 ton cross member with extra bracing.
Hope this helps.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-29-2009, 09:36 PM   #3
muckyp
muckyp's Avatar
I recently discovered that the radiator core support frame mounts are different on the 67-68 and 69-72. The 67-68 is mounted a little higher on the frame.
muckyp is offline   Reply With Quote
Old 09-30-2009, 05:50 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
and 71 and 72 are made of stronger steel than the 67-70.
Old 09-30-2009, 06:51 AM   #5
67/68 frames have a different location for the e-brake cable.
Old 10-01-2009, 08:56 PM   #6
oldcarfart
So basically I can put my '67 cab and front clip on my '73 frame??
oldcarfart is offline   Reply With Quote
Old 10-01-2009, 09:04 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
I am not sure you meant "73 frame, but if you did it is possible but not real easy.
I met a guy once that put a '53 Chevy body an early '80's 4 by 4 frame. He did a good job, but said it took a while.
Danny
Old 10-01-2009, 09:18 PM   #8
PowerPro
so did the 3/4 ton chevy not come with leaf springs in 70? cause I have one, it looks stock...
1970 C20 LWB Fleetside with a 472 Caddy engine! TH400
Restoration in progress
07 Yamaha 650 V-Star Custom
83 Honda V-45 Magna
PowerPro is offline   Reply With Quote
Old 10-02-2009, 07:09 AM   #9
No,that`s adiferent bird all together.
Leaf rear was an option on Chevys.Coils were an option on GMCs.
Old 10-02-2009, 09:42 AM   #10
CG
BlahBlahBlah
Never heard about the 3/4 ton cab mount being higher. Why is that and how does it not affect alignment with the box? I must be missing something very simple.
Old 10-02-2009, 12:23 PM   #11
sweet70beast
sweet70beast's Avatar
I believe that the 3/4 2wd and all the 1/2 and 3/4 4x4s use the same rubber donut cab mounts. If you look at replacements from LMC etc. they list the sameones for 3/4 2wd and all 4x4s and the 1/2 2wd uses a different one. I looks to me like they are taller than the 1/2 2wd mounts. So to keep the cabs sitting in the same place in relation to the bed they had to move the frame brackets down.
Putting our cabs on newer 73 up frames can be done. I had a friend of mine do it. I think the front mounts are in the same place but the rear one on the 73s are inside the frame rails because of the gas tanks. A mount needs to be welded or bolted to the outside of the frame. If I remember right the frame sits alittle lower under the cabs on 73-87s so the frame mounts will sit alot higher on the frame.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 10-02-2009, 01:24 PM   #12
StingRay
StingRay's Avatar
Up here in Canada coils were stock across the board Chev and GMC. Leafs were optional. Longhorns were leaf only Chev or GMC Canada and US.
I don't think the 73 frame has the same wheel base. Longer I believe. It certainly won't have the correct front frame horn for bumper mounting.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 10-02-2009, 04:37 PM   #13
Longhorn Man
73 - 87 takes a lotta work, nothing near a bolt on.
leafs weren't always base on GMC in the states either.
Old 10-02-2009, 06:07 PM   #14
Shyguy
Junior Member
Shyguy's Avatar
I was told that the reason for the larger rubber bushings on the rear cab mounts for 3/4 ton and all 4X4's was to give more cushion and a smoother ride in the cab.
Sounds logical since the suspension on them were heavier duty than on 2 wd 1/2 tons.
Danny
Old 10-03-2009, 01:59 AM   #15
sweet70beast
I personally have never seen a GMC with coil springs and have only seen 2 Chevys with leafs. I can't imagine there is/was alot of them cross ordered.
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 10-03-2009, 02:46 AM   #16
Longhorn Man
and I've personally seen more GMCs with coils verses leafs.
Old 10-03-2009, 09:36 AM   #17
oldcarfart
Being a production frame is the frame common between Chevy and GMC, i.e. drilled for both leafs and coils so changing would be easy enough? IIRC the front crossmembers lack only one or two holes when they are swapped. I will probably keep coils in the rear of my '67 for ease of dropping 4" and with the '73 front clip am shopping for dropped spindles at 2.5". Inputs? Comments? I am open to suggestions (be nice <grin>!!).
