Old 10-02-2009, 11:45 PM   #1
cvalcore
cvalcore's Avatar
spark knock
I have a question i have a 84 chevy one ton 454 that i installed a edelbrock rpm intake and a 750 cfm carb on and it has great power when im driving around in the valley but when i take it up in the mountains i have spark knock and not near the power i was wondering if it could be my distributor that's the problem. also it has been a pain in the neck to get it timed just right ive got the timing right but i just cant get ride of that spark knock. Also i have headers and a duel exhaust with a cross over pipe. Any help would be great.
cvalcore is offline   Reply With Quote
Old 10-11-2009, 09:25 PM   #2
cvalcore
cvalcore's Avatar
Re: spark knock
any one got any ideas
Old 10-11-2009, 11:09 PM   #3
Prong
Re: spark knock
What grade of gas are you running? Also, where exactly is the timing set at?
Prong is offline   Reply With Quote
Old 10-12-2009, 12:02 AM   #4
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: spark knock
The engine is probably warming up too much. A cooler thermostat might help. I suggest tuning the carb with a vacuum guage. Yea, the distributor may be adding too much timing. Especially if the initial timing is set above 6 or 8.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 10-12-2009, 10:17 PM   #5
cvalcore
cvalcore's Avatar
Re: spark knock
the timing is set in the only place that it will not diesel when i shut it off i have always set my timing by ear on all my vehicles i have not checked the degree it is set at i never had a problem with timing until i put the intake and carb on and also it will diesel after only running for 2 min. it also runs pretty cool about 160 degree's.
Old 10-12-2009, 10:32 PM   #6
TurnNBurn
Re: spark knock
I run my big block a 32 deg total timing. I start a 5-6 intial. Check to make sure your weights are not sticking. That will hold it to far advanced a low speeds. Climbing hills will make timing rise but motor slow. Put a few gallons of e85 in your tank if its avaliable to you, its around 104 Octane that should bump up your fuel. That should rid you of the ping. Run a cooler plug, Check for vaccum leaks. Or back the timing off. That kinda of thing
In the past I took the vaccum pot off the dist and used a small file and filed the rod on the vaccum pot so it doesnt pull so far. Worked for me.
9 times out of 10 if it afterruns to much advance, or idle is to high with a vaccum leak.
TurnNBurn is offline   Reply With Quote
Old 10-13-2009, 02:13 AM   #7
nechevy
nechevy's Avatar
Re: spark knock
A raise in elevation sounds like the problem. The higher up you go the leaner the fuel mixture will get and on loads can cause a ping and lack of power. Some cars use a barometer to resolve that. You'll probably have to check you a/f mix and timing
What would foose do?
nechevy is offline   Reply With Quote
