Old 10-02-2009, 06:57 PM   #26
Robert Paul Thomas
1967 C-10 SWB LS-6 T-56
Re: 1967 c-10 ls6
I changed to five lug. Front end came from ECE. The rear end on our trucks is the same through 70, but changes in 71,....3/4 in wider,...I think. Early axles out of a full size impala fit. Mine are alloy axles from Dutchman. I'm changing the front calipers to polished two piston ones from performance online,...really nice product.
Robert Paul Thomas is offline   Reply With Quote
Old 10-02-2009, 07:55 PM   #27
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: 1967 c-10 ls6
Bad arse......
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-02-2009, 07:59 PM   #28
brad_man_72
the boat guy
brad_man_72's Avatar
Re: 1967 c-10 ls6
very good looking swap. a couple of things i noticed are the restrictive air filter (air makes a 90* turn right in front of the tb) and the fuel pump location, mine is also in the front of the fuel cell its fine unless you like to accelerate with less than a half tank of gas, when you hit the gas the fuel runs to the back of the tank starving that awesome ls engine.
i ran a 15.2 added 3 gal of gas (all i had) then ran a 14.7, stock 5.3 4l60e and 3.73. havent been back to see what it would run with enough gas in the tank.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 10-02-2009, 11:28 PM   #29
VA72C10
VA72C10
VA72C10's Avatar
Re: 1967 c-10 ls6
Awesome build....top notch all the way!!!
Old 10-02-2009, 11:28 PM   #30
nuke1
nuke1's Avatar
Re: 1967 c-10 ls6
WOW, that is awesome, glad to see that work, way to go, wish i lived a province or two over to see it in person!
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 10-03-2009, 04:46 AM   #31
Robert Paul Thomas
Re: 1967 c-10 ls6
Brad. The intank fuel pump is the GM one used in the corvette, it was recommended by Ricks Hot Rods, they made the tank. As far as the air filter, S&P recommends this set up. Having said this, I haven't tried either but I will let you know how it works,...should be firing it up once I put the rad support and Griffin Rad in with dual fans.
Old 10-03-2009, 09:14 AM   #32
ulakovic22
Re: 1967 c-10 ls6
Have you put the cab on the frame at all? With the shifter location being changed, where is the shifter in relation to the floor of the cab? Where was it before?
ulakovic22 is offline   Reply With Quote
Old 10-03-2009, 11:42 AM   #33
smallwin67
smallwin67's Avatar
Re: 1967 c-10 ls6
Pfft Too clean.Just kidding man,It looks great.
Doin it one piece at a time.
smallwin67 is offline   Reply With Quote
Old 10-03-2009, 12:38 PM   #34
ed2552
ed2552's Avatar
Re: 1967 c-10 ls6
Wow, that looks amazing. I'd love to add a Gen III/VI to our 67, but time and $$$ are the issues. I would love to have those kind of skills. Keep up the great work!!
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs
72' GMC C2500, 350, TH400(?), Dana 60
'67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST!
'65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT!
09 Yukon Denali 82k Miles 6.2L/6A
ed2552 is offline   Reply With Quote
Old 10-03-2009, 04:14 PM   #35
Robert Paul Thomas
Re: 1967 c-10 ls6
ulakovic, hi, cab hasn't been on yet. I have measured and measured again, it is almost exactly where the stock 4spd would be. Truck was a small hump, and from other posts, I knew I had to change to a large hump,...got a really rust free one out of an automatic, so all I need to do is cut the hole. As far as the T-56, the shifter is actually located in the old inspection cover location. Milled my own shifter mount out of a block and used the old hurst shifter base. Took a 4 spd shifter and removed all the old parts off the end where it goes into the old 4 spd, welded the corvette bracket on and tada!. Mcleod makes the kit, you have to totally diassemble your trans, cut a section out of the shifter rail, and then pin the new mcleod piece into position. Hardest part, once you get over cutting the shifter rail in half, is drilling the shaft. The rail is case hardned, so you have to grind a dimple, if you will, then follow with a pilot hole. If anyone has any questions, feel free to ask, love to help!
