Old 10-03-2009, 02:33 PM   #1
jobberone
76 K10 Fuel sender and fuel questions
I just put the driver's side fuel tank in my long bed. We couldn't find the dang new fuel sender so I've got to get another one.
Does anyone know if its a three or four port design?
I don't want to use the stock fuel lines (which I don't have anyway). I want to route my own lines.
Has anyone reengineered fuel lines that are simpler than the stock configuration? I'll buy another sender but I do need to know if its a three or four port configuration or does it really matter? I can't really see the other fuel sender without taking the bed off now. Not ready to do that right now unless I have to do so. That will disable the truck before I'm ready to finish the work.
Do both tanks have to be vented or just one? Can you draw fuel from the crossover line with a T or is that too far to pull the fuel? Can you draw from one tank and have both equalize? These questions are probably not real bright but I just don't know.
jobberone is offline   Reply With Quote
Old 10-03-2009, 09:20 PM   #2
Prong
Re: 76 K10 Fuel sender and fuel questions
If you have a 3 line fuel pump, then you need a 3 port sender. One for 3/8" fuel feed, a 5/16" vapor canister line, and a 1/4" that is the return from either the fuel pump, or the switching valve (if you have dual tanks). Otherwise, you need a 2 port sender. The 4 ports were used on Blazers and Subs IIRC.
Prong is offline   Reply With Quote
Old 10-05-2009, 12:38 AM   #3
jobberone
Thanks. I bet its a 3 port sender.
