Old 10-04-2009, 11:02 PM   #26
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Re: Transmission trouble
I may just call TCI and see what they say, Fluid level checks out ok after warmup, the tranny uses the radiators cooler, should be adequate because the engine runs pretty darned cool.
mikajo39 is offline   Reply With Quote
Old 10-04-2009, 11:04 PM   #27
mikajo39
mikajo39's Avatar
Originally Posted by highperf4x4 View Post
Wow 3rd at 25? I've never had a tci transmission but I would have thought the shift points were higher than that. Anyway, good luck locating a posi with the gears you want.
Until then, use the shifter to change your shift points!!
I usually manual shift cause its fun, but if I go real light throttle I can get into 3rd at 25, but if I punch it holds its shifts real good.
