drag it like you stole it
quick question again
if i welded a piece of tubing from one trailing to the other horizontally, would they still function the same?
negative camber //LA\\ |
Recovering Truck Driver
I don't think you want something rigid between them, they need to be able to flex independently of each other for uneven surfaces.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
aka Crusher, Crushergmc
No they won't. You would loose articulation (sp). When one wheel went up or down due to road inconsistancies, the other would do the same. It would be funny though, to see you bouncing all over the road
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
It would depend on where it was at. If it were right under the axle, it shouldn't make a difference, but further up could cause problems.
The reason I say this, is the axle is rigid between the control arms, so I don't see what difference a bar would make there. The arms have to twist a little further up to allow one side to travel more than the other.
69 SWB LT1/4L60E www.classicplace.com |
The June Classic Trucks has a article on strengthening them....................Just pick it up................
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
The June Classic Trucks has a article on strengthening them....................Just picked it up................
