Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 10-06-2009, 04:22 PM   #51
Daveboyd
Daveboyd's Avatar
Re: Boyd Welding-67-72 Rear Mount Aluminum Tank
Originally Posted by VA72C10 View Post
Quick question...how much gap between the top of the tank and the bed cross sill ( meaning can the side tabs be moved so that the tank sits a little higher and tucks even more up under the truck without coming into clearance issues with a bed crossmember)
I would assume that moving the mounts anymore would not leave enough clearance for fittings and sending units. this product is a model of MSGROSS's tank and drawings i did not design nor ever install one personally.
Dave Boyd
View Our 63-72 C10 Tank options https://fueltankparts.com/collections/63-72-c10-tanks
Boyd Welding Main Site : http://www.boydwelding.com/
Boyd Online Shop: https://fueltankparts.com/
E: Sales@boydwelding.com
Daveboyd is offline   Reply With Quote
Old 10-06-2009, 04:26 PM   #52
msgross
msgross's Avatar
I can remeasure mine if you want. I think it can be move up an extra 3/4" or so closer to the bed crossmember. The crossmembers are tall enough to clear sending units so that shouldn'e be an issue.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 10-06-2009, 06:21 PM   #53
Daveboyd
Daveboyd's Avatar
Mike i really appreciate all your help!!!
Dave Boyd
Old 10-06-2009, 10:46 PM   #54
VA72C10
VA72C10
VA72C10's Avatar
I'd appreciate it if you could check. I might also modify that crossmember to tuck it up even higher but I at least want it up to the top of the frame rails if possible. Thanks.
Old 10-06-2009, 10:50 PM   #55
BossHogg69
motor exploder
BossHogg69's Avatar
bump for a great price!! Is there a deadline for this buy? I have my truck blown apart at the moment, so now would be a good time to swap the tank to a frame mounted one.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-07-2009, 01:13 AM   #56
Dynomutt
Dynomutt's Avatar
Dave I ran across your site a little while ago searching for custom tanks then came in only to see this post. Must be a sign.
I want to do a bumper fill also but I think the dimensions are going to need to change quite a bit for that. I'm waiting on my bumper to come in (Brothers is taking their sweet time) so I can get it bolted up and get some measurements. I think the fill neck will have to be at the bottom of the frame rail to get enough angle to fill the tank properly. I'm not real sure about that though since I don't have a way to fab it up yet.
Couple of questions though, can you bend (rolled, not square) the lower part of the tank instead of weld so there are only seams showing on the sides? (bends would be front and rear and sides welded in) The top could be welded all the way around since it won't be seen once the bed is on. Also, do you do anything to reinforce the sides where the mounting tabs are? Seems like a lot of weight on a small tab that could stress over time.
Thanks for your time and I'll send you some drawings and dimenstions as soon as I can.
MD
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 10-07-2009, 08:18 PM   #57
Daveboyd
Daveboyd's Avatar
Couple of questions though, can you bend (rolled, not square) the lower part of the tank instead of weld so there are only seams showing on the sides?(bends would be front and rear and sides welded in) The top could be welded all the way around since it won't be seen once the bed is on. Also, do you do anything to reinforce the sides where the mounting tabs are? Seems like a lot of weight on a small tab that could stress over time.
MD
Yes, I can make the front and back ends rolled into about a 3" radius similar to this except on the bottom and both ends
I just finished a tank with the exact requirements yesterday so no problem. your price will reflect that option. At this time i do not do anything to the inside of the tank ends however that can be done also.
call me when your ready and we can discuss pricing and options.
Dave Boyd
Old 10-07-2009, 08:26 PM   #58
Daveboyd
Daveboyd's Avatar
Well I have not set a deadline as of yet but i was thinking of getting this organized and underway around the first week of November. What do you guys think.
Reason for that is I will be closed Oct 22-26th (still available Mobile) and to give people time to get their ducks in a row
I will post a new thread only for this group buy so that there is no confusion over what your buying, whos involved and what the terms are.
Dave Boyd
Old 10-08-2009, 12:01 AM   #59
dan42
dan42's Avatar
Dave, another quick question - what sort of filler tube is gonna work so that you can flush mount it in the bed?
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 10-08-2009, 08:24 AM   #60
msgross
msgross's Avatar
I am thinking about one of these, then connect it with a short piece of rubber hose...if you already have one then have dave install the proper size filler neck 1.5" or so..
If this tank is identical to mine then the filler neck falls in between the metal slats for a wood bed. Steel bed guys might want it moved to the center or far side. This will require a one way check valve, that's why there is a 3/8" threaded bung on the top.
they make them in different sizes as well..
The Garage:
Old 10-08-2009, 11:41 AM   #61
VA72C10
VA72C10
VA72C10's Avatar
I'm putting my filler in the driver's rear stake pocket with a pop up flush cap from a motorcycle. Will that 3/8 check valve down on the tank work or will I need to run the vent up to the actual fill neck?
Old 10-08-2009, 12:54 PM   #62
msgross
msgross's Avatar
I would contact John Fabris on that one, he did a similar filler like yours. You are talking about a vent for filling, im talking about a vent for draining. If you put a non-vented cap (like the flush filler) then you will have to add a vented check valve so that the engine can "drink" without cause a vacuum lock. More than likely you will need both.
Air has to come out when filling at the pump and air needs to come in when running the engine.. the different locations of these keep them from spilling an liquid during normal driving. Everyone also knows what happens to gas in a non-vented plastic container, it swells and blows
The Garage:
Old 10-09-2009, 01:10 PM   #63
texas67chevy
texas67chevy's Avatar
Count me in for a standard. Have a few questions though... I am gonna flush mount a ventless cap in the wood bed, am I going to need a second bung hole for two vents or is the one hole ok. Also I need the filler neck to at least be somewhat centered in a wood plank does anyone know for sure how far off it is on a fleetside?
texas67chevy is offline   Reply With Quote
Old 10-09-2009, 02:18 PM   #64
71cadc10
71cadc10's Avatar
here's what I'm laying out for a steel bed, with EFI.
I sent this to Dave to review...anybody else see something here let me know.....I basically took msgross' drawing and tweaked it a bit.
My measurements would put this about 1/4" clearance to the bottom of the bed cross sills. So you could move the side flanges down to 4" if you wanted it TIGHT against the bed. I left some room to run wires if needed.
capacity calculates to 19.6 gallons BTW.
Thanks,
Andy
71 C10 long bed, 2003 6.0L, 06GTO E40, T56, 12bolt 4.10 rear
71cadc10 is offline   Reply With Quote
Old 10-10-2009, 12:55 AM   #65
VA72C10
VA72C10
VA72C10's Avatar
Thanks,
Andy
Looks good and the side exit is what I would need. If an inch was taken off the height that would also work for me. I don't mind losing a little capacity for ground clearance....
Old 10-10-2009, 11:20 AM   #66
silver7
silver7's Avatar
I was wondering the same thing texas67chevy. msgross, can you confirm if your design will allow some adjust of moving the tank side to side to center within a wood plank if neeeded? Thanks
silver7 is offline   Reply With Quote
Old 10-10-2009, 11:57 AM   #67
msgross
msgross's Avatar
My design will allow the filler to fall in the center of the plank. You can't go center of the wood bed unless you want to cut one of the metal strips holding the bed wood down. post #29 has my tank plans.. the side brackets could be adjusted for a tighter fit against the bed cross sill.
The Garage:
Old 10-10-2009, 04:44 PM   #68
msgross
msgross's Avatar
I measured it and it sits 3/4" below the wood bed crossill, if you lowered your flanges 3/4" then it would be tight.
any royalties for the design?
Here are some more pics.
1st: you can see the wood bed mounting holes in the crossill, it's darn near perfectly in the center or you have 3/4" of travel left or right..
2nd:It could be raised 3/4" or shorten the tank for even more clearance. It has approx 3/4" on the sides as well as below the crossill, I wanted a little extra room incase I do a trap door filler with the cap that's on it.
3rd:This is a fleet short bed and it hangs about 5" below the fram rail in the rear and maybe 7-8" in the front. I made it slant downward in the front so you can drink every drop of fuel since the outlet is in the front passenger corner.
If anyone else needs pics or measurements i'll leave it mocked up for another day.
The Garage:
Old 10-11-2009, 01:28 AM   #69
DMARCUM123
what gauage alum are you using for the tanks
DMARCUM123 is offline   Reply With Quote
Old 10-11-2009, 03:02 PM   #70
texas67chevy
Thanks msgross, thats exactly what I was lookin for... Im down for a standard tank for sure.
Old 10-11-2009, 03:05 PM   #71
silver7
silver7's Avatar
For sure. msgross, thank you for your help.
Old 10-12-2009, 04:10 PM   #72
71cadc10
71cadc10's Avatar
Here's an update to the drawing...the side fill will just have 2 pcs welded like shown.
The material is 1/8 aluminum as listed in the first post.
Other notes: there are 0.625 radius shown on 4 of the edges of the tank, these are bent edges and won't be weld seams. Basically the tank is 2 "U" shaped pieces that are fit together and welded.
EFI version will have baffles added, and a Walbro GSS342 pump with a sock filter on it. The return will be on the passenger side somewhere and will return fuel in an area outside of the baffled pickup so fuel aeration is minimized.
I have experience with the GSS342's, they are a great pump. At 14v running pressure is approx. 60 psi, perfect for GM fuel injection setups (Gen III or IV). This pump is supporting 500 rwhp in my LS1 GTO and been in there for 27K miles daily driven. So I'm very happy with the performance and longevity.
If you have Carb setup now, and thinking EFI later (which I am) then there are pressure regulators that will work with the high inlet pressure and bump down to the 7psi or so that a carb wants. Will return a good bit of fuel but should work just fine if the return line is sized large enough. I eventually want to "grow into" and EFI setup when funds and time allow...so this will be one less hassle when I'm ready.
Cheers...
Andy
Old 10-13-2009, 10:44 AM   #73
VA72C10
VA72C10
VA72C10's Avatar
Wouldn't that side fill need to be a little lower for bedfloor clearance? Or is that assuming you are leaving the side brackets where they are and not the additional 3/4"
Dave Boyd....
If I do the side fill on mine, have the side flange 3/4 higher so the tank fits flush, and take 1" off the bottom, would that change the pricing at all?
Also, any chance of me paying today or tomorrow to get mine produced as soon as you have time? I am ready for my tank as soon as I can get it.
Mine is carb setup...not EFI...
Old 10-13-2009, 12:30 PM   #74
71cadc10
71cadc10's Avatar
no, if you leave the brackets where they are, there is 3 3/4 from the top of tank to bottom of a steel bed floor. So the fill neck is 3" to the top...would leave you 3/4" to work the fill hose on the neck and get a clamp in there.
If you push the top of tank up flush to the cross sills, then yes the top of the side fill would be tight to the floor. Might need to lower the side fill overall height if Dave can do it. The steel bed cross members are 3" deep from what I measured.
Old 10-13-2009, 01:04 PM   #75
Daveboyd
Daveboyd's Avatar
I HAVE POSTED A NEW THREAD FOR THE GROUP BUY HERE
http://67-72chevytrucks.com/vboard/s...d.php?t=367055
PLEASE USE THAT FOR INQUIRIES DIRECTLY RELATED TO THE GROUP BUY.
Dave Boyd
67-72 truck, aluminum tank, boydwelding.com, fuel tank, tank relocation
