Old 10-06-2009, 06:14 PM   #1
HzEmall
HzEmall's Avatar
VIN on the frame?
Where would the VIN be on the frame of the C10?
I have a 80 cab but I want to make sure it's the matching frame for it (parts truck being rebuilt)
Tim Baillie
Installer/Designer/Fabricator
Trick Factory Customs
Company - www.trickfactory.com
Personal - www.hzemall.com
Instagram - @hzemall
HzEmall is offline   Reply With Quote
Old 10-06-2009, 06:16 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: VIN on the frame?
its on the driver side by the transmission cross member
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 10-06-2009, 06:17 PM   #3
HzEmall
HzEmall's Avatar
Originally Posted by flamingbig10 View Post
its on the driver side by the trans mission cross member
Inner or outter of the frame ?
Tim Baillie
Old 10-06-2009, 06:19 PM   #4
flamingbig10
6.0 powered square
outer
Aaron
Old 10-06-2009, 06:19 PM   #5
HzEmall
HzEmall's Avatar
Tim Baillie
Old 10-06-2009, 07:09 PM   #6
Keith Seymore
Keith Seymore's Avatar
I would have said passenger side, top of the rail under the cab.
That's where we put 'em in Flint.
Where was your truck built, do you know?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-06-2009, 07:11 PM   #7
HzEmall
HzEmall's Avatar
K
Don't know, that's the problem.
The frame has dual tanks, but the cab isn't wired for it.
Tim Baillie
Old 10-06-2009, 07:17 PM   #8
flamingbig10
6.0 powered square
mine was built in st Louis
Aaron
Old 10-06-2009, 07:18 PM   #9
74 C-30
Dually Pride
74 C-30's Avatar
Keith, do you know where the location is on a Canadian '74? thanks!
If I have to explain, you wouldn't understand.
'74 Chevy C-30 350/4 speed/dually
'94 Ford Ranger
74 C-30 is offline   Reply With Quote
Old 10-06-2009, 07:22 PM   #10
Keith Seymore
I see; I'm guessing there isn't a VIN on the cab (or you think it's the wrong one) and that's why you are looking for the one on the frame? Do you happen to have the cab and box off?
At any rate - I believe it should be on the top of the rail, because of the way the "stamp" pressed the numbers in.
K
1979-1986
1986 - 2019
Old 10-06-2009, 07:23 PM   #11
Keith Seymore
Thanks, Aaron.
Is it on the top of the rail, or when you say "outside" does that mean you can view it from beside the truck?
K
1979-1986
1986 - 2019
Old 10-06-2009, 07:25 PM   #12
Keith Seymore
Assuming it was built in either Oshawa or Flint I'd say top of the rail, pass side, under the cab.
K
1979-1986
1986 - 2019
Old 10-06-2009, 07:26 PM   #13
HzEmall
HzEmall's Avatar
K
The cab has a VIN, just not sure if it's the same on the frame. The cab and frame are still together.
Tim Baillie
Old 10-06-2009, 07:27 PM   #14
whiskeydented
whiskeydented's Avatar
Mine on my 78 is actually stamped twice. Is that normal? It is stamped once passenger side top rail under cab and once again about 10 inches towards the rear. Truck was built in Canada if it makes a difference.
whiskeydented is offline   Reply With Quote
Old 10-06-2009, 07:28 PM   #15
flamingbig10
6.0 powered square
if I had a driver side fuel take, most of the numbers would be hidden
Aaron
Old 10-06-2009, 08:05 PM   #16
TravisMartin
Curmudgeon of Poor Means
I have an 82 C20 built in StLouis; it's stamped on the driver's side under the cab on top of the rail (you wouldn't be able to see it with the cab in place) and if memory serves it's stamped again on the same rail somewhat to the rear, but I'm a little foggy on that one. If it matters I can look at it tomorrow in the sunlight.
Travis
TravisMartin is offline   Reply With Quote
Old 10-06-2009, 08:08 PM   #17
TravisMartin
For what it's worth, it's only the last 8 of the VIN; I assume that was S.O.P. (Kieth?)
Travis
Old 10-06-2009, 10:05 PM   #18
HzEmall
HzEmall's Avatar
Travis
So it isn't going to tell me anything.....
Tim Baillie
Old 10-06-2009, 10:55 PM   #19
TravisMartin
It shouldn't be a problem since you're only trying to verify if the frame & cab match...the first 9 digits of the vin tell you it's made in USA, GM, Chevrolet, tonnage, 2 or 4 doors, 2 or 4 wheel drive and which engine it shipped with...the last 8 tell you year, plant it was built in, and the last 6 are unique to your truck. You already know everything the first 9 tell you.
Make sense, or did I confuse you? All the shop manuals have a chart that explains what the various letters/numbers in the VIN mean. I've seen the same chart in the front of the LMC catalog too. I'm assuming we're talking about a 1981-up vehicle; 1980 and back used a different system. In 1981 all cars built everywhere adopted a 17 digit VIN system designed to standardize how they were interpreted. The first digit, for example, tells you the country of origin...1 is USA, for example, J is japan, W is Germany...so I'm assuming yours starts off with a 1. Then a G for GM. There oughta be a chart online somewhere, but I didn't find a good one with a quick Google search. But surely you have an LMC catalog? Some of the others might have it too. Sorry for the long post; hope I made sense. If not, just ask; I'll keep looking for a better site to link to.
Old 10-06-2009, 11:09 PM   #20
TravisMartin
Found a good site; GM no less. Click on the model year of your truck and it'll give you a pdf file of how to interpret each letter/number of your VIN...
http://service.gm.com/dealerworld/vincards/
Travis
Old 10-06-2009, 11:11 PM   #21
HzEmall
HzEmall's Avatar
Cool, I just need to find it on the frame
Tim Baillie
Old 10-07-2009, 07:11 AM   #22
Keith Seymore
Travis
Sounds right. Twice on the same truck is within reason, too.
K
1979-1986
1986 - 2019
