Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 10-07-2009, 08:00 AM   #1
chevyman8
chevyman8's Avatar
Need help picking a posi
I picked up a 12 bolt rear the other day that I'm going to drop 3.73 gears into. I also want a posi, but I know what to get. My '84 is my daily driver that is also taken to the track. What's a good posi to drop in it? What are you guys runnin?
chevyman8 is offline   Reply With Quote
Old 10-08-2009, 03:06 PM   #2
americanmusc1e
americanmusc1e's Avatar
Re: Need help picking a posi
I'm runnin' an open differential and in need of a posi (and gears) too......subscribed
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 10-08-2009, 03:06 PM   #3
Outlaw72
Hay Team!!
Outlaw72's Avatar
I have an Auburn in mine.....it has held up very well. I shattered the rear in my truck launching on the bottle almost 2 years ago and that is the only part I did not have to replace. Still going strong..
1972 Chevrolet Cheyenne LWB "Orange and White" 8)
Outlaw72 is offline   Reply With Quote
Old 10-08-2009, 07:05 PM   #4
AirMale
AirMale's Avatar
I've had both Eaton and Auburn and prefer the Eaton. Eaton is rebuildable and hooks straighter.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 10-08-2009, 08:37 PM   #5
BossHogg69
motor exploder
BossHogg69's Avatar
I put an Auburn in my a DD '92 C1500 5.7/5 spd that I took to the track every now and then. I liked it because it was smooth and didn't make any noise. I had 3.73's, Lakewood traction bars and a 4" rear drop and it hooked pretty good.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 10-08-2009, 09:29 PM   #6
chevyman8
chevyman8's Avatar
I appreciate the input. How about gears? I heard Richmonds whine and break a lot. I was told Motive gears are the way to go.
Old 10-08-2009, 10:25 PM   #7
BossHogg69
motor exploder
BossHogg69's Avatar
i used Yukon gears in my '92 when I put in the Auburn. they were quiet too, and I never had any problems out of them either. I've never used Motive or Richmond.
Adam
Old 10-08-2009, 10:40 PM   #8
ProStreet71
If set up properly, gears should not whine regardless of manufacterer.
ProStreet71 is offline   Reply With Quote
Old 10-09-2009, 12:03 AM   #9
wheatlandbrawler
wheatlandbrawler's Avatar
couldnt agree more... and i run richmond's in my 8 second malibu.... nver had a problem.
1968 swb RIP 408. 388 roller monster mouse, richmond 5 speed. and alot of the stuff that makes you happy. build link. http://67-72chevytrucks.com/vboard/s...d.php?t=389826
wheatlandbrawler is offline   Reply With Quote
Old 10-09-2009, 01:17 PM   #10
Marv D
Registered Truck Offender
Marv D's Avatar
Ditto, I would prefer to spend the few extra bucks to get the better unit. You will get a little clutch chatter accelerating through sharp corners without the L.S. additive, but it eases as the clutches break in.
I did break a set of Richmond street gears transbrake launching in the 3380 pound truck running low 12's, but have never had a seconds issue with the Richmond 9" Pro gear run in my low 9second Nova. I don't know if it's design or case flex but I have heard of more gears breaking in the GM 12bolt housing than the other popular differential cases (Dane & 9" ).
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 10-21-2009, 01:43 AM   #11
CreditGod
call peyton performance out of texas he builds rear ends for all of the big boys in the south he will shoot you straight
I have an auburn in mine.
hope this helps
CreditGod is offline   Reply With Quote
