04-12-2003, 10:04 PM | #1 |
headers will not fit ???
I have a set of Headman headers for my 72 BB and they will not fit they are the correct application but it's a definite no go.
Anyone else experiance this or can you recommend a better fitting set. |
04-12-2003, 10:09 PM | #2 |
Nothing fits but the oil
Where on your truck do they not fit??
Land of the free Because of the brave |
04-12-2003, 10:16 PM | #3 |
I havent had experience with a big block, but I did put Headman Headers on my 1970 with a 350. One tube on each side hit the frame rail for some reason, so I ended up bending each tube in that spot. Fits ok now.
Scott Moore 70 Chevy 3/4 ton Custom Camper 72 Chevy 3/4 ton 4X4 |
04-12-2003, 11:03 PM | #4 |
sometimes for header installation it's good to have the engine mounts disconnected and a lift hooked to the engine to rock it a little to one side in order to slip the headers in and ocassionally a BFM comes in handy for dimpiling a tube hear or there for clearance
04-12-2003, 11:15 PM | #5 |
Thats the Hillbilly way
I use Dynamax BB header,s ,had to replace the motor mount on one side it was sagging about an inch .Fit great after that.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
04-13-2003, 01:37 AM | #6 |
I just put in a set of the headmen elites on my 402 '67 C10 yesterday. I had to grind a very small amount off of the bottom of the flanges on the cyl head where they were hitting on my ARP head bolts. I am using '72 style motor towers and mounts. They clear my frame and I can even use the orginal 2qt canister oil filter with them. I can get you the part number if you want, the only difference between the elites and regulars is the coating and flange thickness.
'67 C10 short box fleet side wood bed small rear window frame off restoration. 396BB,Th400, ps, pwr disc 5 lug, posi 3.07, 2000 Suburban 60/40 pwr seats, 2.5" front drop 4" rear, powder coated running gear. |
