Old 10-09-2009, 05:24 AM   #1
Libertad
No Nonsense
Libertad's Avatar
15X10 backspacing help
Well I got some used rims 15x10 but there is not enough backspacing. In other words the lug bolts are to short. Can I replace the lug bolts to longer ones or are they permanently attached to the drum brake cover? I have a 75' C10
Bi-Centennial Blazer
Libertad is offline   Reply With Quote
Old 10-09-2009, 08:27 AM   #2
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: 15X10 backspacing help
no problem goto your local good parts store and ask the for a wheel stud and tell them you need one at least X" longer...take them home pull the drum grab a BFH and give then a couple good wacks they will pop out the back....check to see if they will come out with out hitting the backing plate if they come out put A new one in add a filler like a big nut and a coulpe washers then put on the lug nut on and tighten it up and pull it to seat...once there all done and the wheel is on be sure to check them pretty regulay until you feel comfortable and the new studs are seated..if they don't clear the backing plate you may have to pull the axles out
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-09-2009, 08:32 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
It's not the backspacing of the rim you are talking about it is the hub thickness of the rim. Backspacing is the distance from the mounting surface to the back edge of the rim.
You can knock the wheel studs out of the axle and replace them with longer ones. There were several different knurl diameters so you will have to knock one of yours out and measure it to order the right ones.
The C-10 should use 7/16" threads so look up a 75 Corvette in the parts store to get one of their wheel studs. Theirs are about 2" long due to the design of their brakes so they should be longer than yours and may be the same knurl diameter.
68 TT is offline   Reply With Quote
