10-09-2009, 11:59 AM | #1 |
73-87 1ton axles on a 71 Blazer
I'm sure this has been covered somewhere in here, but I couldn't find it. Here goes: Will a Dana 60 front and 14 bolt rear from a 73-87 1ton (I don't know exactly what year) bolt directly to a 71 Blazer? Or do you have to move perches / modify stuff?
You can't get out if ya don't get in |
10-09-2009, 12:22 PM | #2 |
Certified Hobbiest
Re: 73-87 1ton axles on a 71 Blazer
i believe the d60 will bolt in but the 14b might need to relocate the perches
10-09-2009, 04:09 PM | #3 |
Yup, I did it to my 72
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks |
10-09-2009, 05:19 PM | #4 |
Both axles will bolt in as long as the 14 bolt is from a K30. '73 - '87 one tons have a narrower spring spacing than the half and 3/4 tons making it the same as the '67 - '72 half and 3/4 tons. The rear shock mounts will have to be relocated.
Tim |
10-09-2009, 06:20 PM | #5 |
Was`75 the first year K/30?
10-09-2009, 09:48 PM | #6 |
Late '76 or '77, depending on how picky you want to be. It was '75 with dodge, though...at least in terms of having the desireable D60 front.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 10-09-2009 at 09:49 PM. |
10-09-2009, 10:37 PM | #7 |
GM intoduced the K30 to their lineup in 1977 model year. I bought one and have had at least one K30/Dana 60F equipped 4x4 in the drive ever since!
10-11-2009, 02:50 PM | #8 |
Thanks for the advice guys. I think these axles came in the same truck. I don't think any 3/4 tons had a 60 front (they were all D44HD as far as I know). So it's likely the 14bolt is from a 1ton. So then from the valuable info here, I will have to relocate the spring perches. I should be able to figure that out.
10-12-2009, 06:41 AM | #9 | |
Tim |
10-12-2009, 08:33 AM | #10 |
14-bolts were in all 3/4Ts after`72 as well.
The first K/30 I knew of was a`77 back then.I`m not sure where the`75 came from (big blocks in 4wd?).
