Old 10-10-2009, 10:42 PM   #1
ryansiki
Question Gmc vs chevy(cosmetic differences)
I was just wondering what are the cosmetic difference between GM and Chevy trucks(64 particularly).Also if I were to change the from one type to another would this cause any major problems when registering it.
ryansiki is offline   Reply With Quote
Old 10-10-2009, 10:59 PM   #2
Stepside65
Still Truckless!
Stepside65's Avatar
Re: Gmc vs chevy(cosmetic differences)
unless you know what to look for you can't really tell the difference. the turn lenses were shaped differently, the grills are entirely different, the GMC's typically had a v6 badge on the side of the hood, chevy's have a badge on the fender that doesn't exist on the gmc, the custom cab trim was different as well, and finally some of the two tone paint jobs were sprayed differently. Oh and the GMC's had the V6 big blocks. Other than that pretty much the same trucks
~James
Truckless
2009 Hyundai Sonata<~~Wife's sedanomatic
1997 Nissan Pickup Father-in-law's tonka toy I am forced to drive
Founder of The 60-66 Club
Tutor Et Ultor
Stepside65 is offline   Reply With Quote
Old 10-10-2009, 11:07 PM   #3
ryansiki
I am not concerned about badges and other little stuff,so the only real major difference is grill.right?
Old 10-10-2009, 11:25 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Besides the grille the main differences between Chevy and GMC are the hood, tailgate, dashboard, stainless cab trim on the deluxe models, engines & engine mounts, and rear axles.
I think you could cosmetically make the truck look like either a Chevy or GMC, so long as the vin matches the title. Even if it looked like a Chevy for example, if it really is a GMC that's what the title/registration will continue to show.
Old 10-11-2009, 12:28 AM   #5
ryansiki
OK, thanks for the info
Old 10-11-2009, 12:41 PM   #6
LILRED66
LILRED66's Avatar
Most GMC 1/2 ton & 3/4 ton trucks were factory-equipped with leaf packs in the rear and their Chevrolet counterparts were factory-equipped with coils/trailing arms.
LILRED66 is offline   Reply With Quote
Old 10-11-2009, 02:15 PM   #7
Northern lights
The BIGGEST diff IMO is the dash. the dash itself cannot be changed (in practical terms) and nothing in the dash is interchangeable. All other cosmetic differences ,grill, trim, clearance lights, badges etc can be interchanged, although the lights require a hood change.
Northern lights is offline   Reply With Quote
Old 10-12-2009, 01:54 PM   #8
Long n' Low GMC
what would be required in swapping a GMC grill for a Chevy?
Long n' Low GMC is offline   Reply With Quote
Old 10-12-2009, 02:44 PM   #9
markeb01
Senior Enthusiast
markeb01's Avatar
Assuming the Chevy grill is attached to the truck via the headlight mounting brackets like the GMC, I think all you'd need to do is hold it in position, mark the hole locations and drill new mouting holes if needed. If you're going from 4 headlights to 2, you'd also need to change out the headlight harness. If the rest of the wiring is stock, you can buy the correct version from a number of suppliers, including the following link:
http://www.americanclassic.com/asp/d...to&exyear=1966
Old 10-12-2009, 06:16 PM   #10
LILRED66
LILRED66's Avatar
By dash, you mean the gauge cluster or warning light cluster, correct? The actual steel dash, from "A" pillar to "A" pillar is interchangeable between Chevy/GMC of the same years, ie, '60-'63 Chevy truck dash interchanges with the '60-'63 GMC truck dash, the same for the 4-5-6.
Old 10-12-2009, 10:25 PM   #11
64krusty
64krusty's Avatar
the canadian GMC trucks have the same suspension,motor and rearends as the Chevys,no v6 for us.
Don't mess with your registration in BC,if ya want a GMC to look like a Chevy just change the grill and hood,and you could always cut out the dash and weld in a Chevy dash.
I`ve bought a couple over the years that were mixed up,mostly GMC`s that had Chev hoods.
64krusty is offline   Reply With Quote
Old 10-13-2009, 10:24 AM   #12
Northern lights
Actually, I meant the steel dash from A pillar to A pillar. I know it CAN be changed but what I meant was that it wasn't practical to do for many/most people as it requires, of course gutting the dash then cutting out spot welds and welding in the other dash. Not something that everyone is equiped to do either tool wise or ambition wise. Not as simple as changeing the hood, grill or mouldings.
