Old 10-11-2009, 05:45 PM   #1
wHATANERD
wHATANERD's Avatar
Dome Light Switch in door ?
Hello everyone, I brought home a cab to replace the one on my truck yesterday, and upon checking it out closer I noticed is doesn't have any holes in the the door frame for a dome light switch on either side. I've never seen a cab without the switches and am wondering if someone may have welded them up. Has anyone else every seen a cab missing these hole from the factory?
1969 C/10 Longbed undergoing rebuild.
Old Chevy's Never Die, They Just Rust Around The Edges
wHATANERD is offline   Reply With Quote
Old 10-11-2009, 05:48 PM   #2
wHATANERD
wHATANERD's Avatar
Re: Dome Light Switch in door ?
Here's a photo of the door opening
Old 10-11-2009, 06:28 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Nope, there were trucks without the switches mounted. I put the switches on my 72 truck when I had it, so it can be done easily. All you are creating with the switch is the ground circuit, so it is not hard. the switch goes on the flat part that is stick out slightly in the middle of the frame.
Frank
Old 10-11-2009, 08:06 PM   #4
wHATANERD
wHATANERD's Avatar
Thinks for the reply, Yes, I will be adding them to this cab as well.
Old 10-11-2009, 08:39 PM   #5
red71c10
The Red Menace
red71c10's Avatar
It's a fact. The base model trucks have no door jamb switches and the dome light can only be turned on by turning the headlight switch all the way to the left. It doesn't bother me so I'll leave mine the way it is.
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 10-11-2009, 09:01 PM   #6
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
I'm pretty sure that all stepsides came without door switches unless optioned for them. Mine sure doesn't have any and I don't care.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-11-2009, 11:07 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
all the trucks came without them unless optioned otherwise, it was an option on all 10 - 30 C or K trucks. It was not avalible at all before '69.
Before someone says "its not listed on my SPID...
It was part of some option packages... but, that is an optional package, as in not base equipment.
Old 10-20-2009, 09:39 AM   #8
wHATANERD
wHATANERD's Avatar
I appreciate the info, I'll probally be drilling the holes and tapping them to accept the switches.
Old 10-20-2009, 04:57 PM   #9
piecesparts
I believe the switches will "Self-tap" themselves into the sheetmetal.
Frank
Old 01-08-2010, 12:06 AM   #10
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Hello fellers, could someone post a picture on where to mount the switch, my truck doesn't have them either and I don't understand exactly where they are mounted if they were ordered from the factory. Thank you
Camaro_nut2001 is offline   Reply With Quote
Old 01-08-2010, 11:12 AM   #11
wHATANERD
wHATANERD's Avatar
I don't have pictures of my old cab, but this might help.
Old 01-08-2010, 12:45 PM   #12
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Yeah, they sort of do. I had to replace one on my '72 and it fit somewhat looser than the old one did. Wouldn't really tighten up. I left it be for now and it works, even being a little sloppy in the hole. When I restore I'll weld that hole up and re-drill it.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline   Reply With Quote
Old 01-08-2010, 08:52 PM   #13
Camaro_nut2001
Thanks a lot. Helped me greatly.
