Old 10-12-2009, 07:12 AM   #1
MrBlue
MrBlue's Avatar
How hard does the heater blow?
Greetings,
How hard should the heater blow? It does not seem to be moving much air. Could this mean the air side of the heater core is plugged up?
MrBlue
MrBlue
72' C-10 350 TKO-600 Current Project
54' Ford F-100 Life Long Project
MrBlue is offline   Reply With Quote
Old 10-12-2009, 07:28 AM   #2
cdowns
cdowns's Avatar
Re: How hard does the heater blow?
not uncommon that leaves mouse nests and 40years of crap plug things up for little to no air flo
Old 10-12-2009, 08:57 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
..with cdowns. I just took the heater box out of the '69 and it was full of mouse nests. They also chewed holes in the plastic blower fan...
The bad thing is you have to pull the inner fender down to get to a couple of the bolts/screws to get it apart. If it is a non a/c you can try pulling the blower assembly out and vacuum out that area. To do that you have to remove the hood hinge on that side. If you remove the hood hinge be sure to mark around the top and bottom with a sharpie so you can get it back in the same place.... Nothings easy..
LockDoc
Leon
Old 10-12-2009, 09:03 AM   #4
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
or listen for the fan they wind up pretty good...if your not hearing it then maybe your heater fan relay is bad...
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 10-12-2009, 10:00 AM   #5
68gmsee
Active Member
68gmsee's Avatar
My two trucks don't move a lot of air either. Granted it's enough for the small cab but it's not like what you feel in cars or larger suvs. I think they are made specifically for smaller areas.
Another thing that may slow the fan down is the bushngs needing lubrication. Should be a post with a picture around somewhere where a member drilled a small hole through the enclosure to oil the fan.
68gmsee is offline   Reply With Quote
Old 10-12-2009, 12:52 PM   #6
69GMCLonghorn
69GMCLonghorn's Avatar
There are 100 different things to check. The guys above have named off the major ones. I had a really bad problem getting mine grounded properly. At one point, I got pi**ed off and ran a huge gauge wire directly from the battery ground to the blower fan. That did the trick. (I later found a better ground closer to the fan, but that at least told me what the problem was).
Another thing to check is your switch. The stock switch is a 3 speed switch. Make sure you hear a difference in each "click". If not, it could be a switch issue.
69GMCLonghorn is offline   Reply With Quote
Old 10-12-2009, 02:07 PM   #7
turp mcspray
turp mcspray's Avatar
If your truck is a non a/c truck, switch to an a/c fan motor. It will move more air.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-12-2009, 02:43 PM   #8
dhaymaker
dhaymaker's Avatar
Thumbs up Re: How hard does the heater blow?
With very few exceptions, virtually all my 1967 -1972 trucks have been big time air movers! If not, I first ensure the leaves, critters, etc. are cleaned out. Next thing to check is the fan motor. If you can hear it run, but you do not distinctly hear the different fan speeds, something is wrong. The primary culprits are the switch, the ground, or the fan motor itself is bad.
don
"The DRBMan"
2014 Audi A4 (The Wife's Daily Driver)
2017 HD Ultra (The Cruiser)
2003 HD Fatboy (The Ride)
2001 Chevy Suburban (Another back up!!)
For the first time in forever, not a single 67-72 Chevy truck, Blazer, or Suburban on the property! Basically retired and getting the new Motorhome ready for some traveling. Doing a bit of work on the house getting it ready to sell! LOL!!
dhaymaker is offline   Reply With Quote
