Old 10-12-2009, 12:08 PM   #1
remist17
remist17's Avatar
Front Wheel Bearings. How do you know when bad?
I have a 93 Silverado 4x4 that has a good nosie coming from the front end. Noise changed with speed. Hav enot had a chance to see if it happens in 4x4. In 2 wheel drive the noise seems to have gotten louder at 55 (cruze speed). The funny thing is when its cold and sits for a while it takes some time to hear it. I am thinking it needs to warm up? I am thinking its either the dif bearings or wheel bearings. I do not know how to check to see if the wheel bearings are bad. Can any one tell me? I am hoping I can just repalce the wheel bearings in stead of getting the front differential worked on !!
2013 Chevy Silverado, Z71, 5.3L, 4 door
2005 Chevy Silverado, Z71, 5.3L, 4 door, 3.40
Support the Troops.
remist17 is offline   Reply With Quote
Old 10-12-2009, 12:57 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Front Wheel Bearings. How do you know when bad?
You may want me to move this to the 4WD forum. Let me know.
Member Nr. 2770
Old 10-12-2009, 02:45 PM   #3
remist17
remist17's Avatar
If you think this is were that needs to go. Please move.
Support the Troops.
Old 11-13-2009, 05:03 PM   #4
remist17
remist17's Avatar
bump
Support the Troops.
Old 11-13-2009, 06:31 PM   #5
Gene
Gene's Avatar
If it's anything like my 99 you might look at the ABS sensor, mine came out of the wheel bearing housing and let dirt crud and anything else in there(they are just siliconed in). And if so, don't plan on just replacing the bearings, mine I had to replace the whole bearing carrier.
Gene is offline   Reply With Quote
