Old 10-15-2009, 08:59 AM   #1
burke117
original ride height????????
Hey guys. I am new to the forum. I have a 1968 chevrolet C10 2WD stepside, I am wanting to lower it but I am unsure if the original springs have settled. Does anyone know the factory ride height of this truck so I can determine how much of a drop to order? Any help you can give would be greatly appreciated.
burke117 is offline   Reply With Quote
Old 10-15-2009, 02:42 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: original ride height????????
burke117, here's what I would suggest. Each application will be different (tire/wheel sizes), so you will end up with a wide array of measurements from board members. Check out ECE (Early Classic Enterprieses) drop page here.
Now here's my '69 CST SWB that I recently lowered. It was running 15x8 rallys with 235 75R15's on all four corners. The springs on my all original truck (93k miles) hadn't settled to much. To start out with, it had the following measurements:
Driver's Side Front: 33 1/2"
Driver's Side Rear: 33"
Passenger Sde Front: 33 1/4"
Passenger Side Rear: 32 7/8"
After the 4.5/6" drop it ended up the with the following measurements:
Driver's Side Front: 28"
Driver's Side Rear: 29"
Passenger Side Front: 28 1/4"
Passenger Side Rear: 28 3/4"
At the moment I am unable to post pictures, but refer to my build thread in my signature (Project Blank Slate) and jump to page 2 for the beginning of the install. Within this build it will have the before/after pics of the installed drop.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 10-15-2009, 03:03 PM   #3
nicolas72gmc
nicolas72gmc's Avatar
X2 on what Nate typed.
I took measurements on mine before and after also. I know these are really close to stock height tires so it should be close. My numbers were pretty close to Nate's.
Before on 235/75/15's Drivers Front -- 31-3/4
Pass. Front -- 31-1/2
Drivers Rear -- 34-1/2
Passl. Rear -- 34-1/4
After lowering 3.5/5-- Drivers Front -- 27-1/2
Pass. Front -- 27- 3/4
Drivers Rear -- 29
Passl. Rear -- 29-1/4
Hope this helps.....
Nick
"Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson
1968, GMC, SWB, Project
1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components.
1972, C/10, LWB, 350 vortec, th350
nicolas72gmc is offline   Reply With Quote
Old 10-15-2009, 05:51 PM   #4
mikey531
mikey531's Avatar
where did you measure to get the stock height?
mikey531 is offline   Reply With Quote
Old 10-15-2009, 07:22 PM   #5
seafoam68
seafoam68's Avatar
The LMC catalog shows a diagram on their drop spindle page. It measures at the trim line above the front and rear wheels. You can check it out online at LMC.com
seafoam68 is offline   Reply With Quote
Old 10-15-2009, 08:11 PM   #6
nicolas72gmc
I've always measured at the wheel arch. IMO it is a good place, can't really mess it up.
Nick
Old 10-15-2009, 08:22 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
w/ Nick, that's where we measured mine.
-Nate
Old 10-16-2009, 08:40 PM   #8
burke117
thanks guys. My truck doesn't have any trim on it so LMC's chart didn't help. I now can measure and compare to figure it out. thanks again.
