Old 10-15-2009, 01:39 PM   #1
Devil Pup
Devil Pup's Avatar
2wd to 4x4 frame swap
Im looking to buy a 4x4 frame and switch my 69 2wd over because i want it lifted "my preference" because no one makes a kit for the 2wd but everyone under the sun has one for the 4x. Has anyone done this or know of the work that is involved? i figure almost all would mount up? just have to replace the body mounts and such but then again i have no clue? pics of any conversions? Thanks, Mark
Lifted 2wd 1969 C20/ 5.3LS/4L60E :http://67-72chevytrucks.com/vboard/s...d.php?t=728388
Devil Pup is offline   Reply With Quote
Old 10-15-2009, 06:32 PM   #2
bhoeger70
bhoeger70's Avatar
Re: 2wd to 4x4 frame swap
I just finished putting a 67 2wd body on a 71 4x4 frame, you will need 4x4 or 3/4 ton body mounts and a high center hump for the floor of the cab other wise it bolted right on.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
Old 10-16-2009, 12:31 AM   #3
Captainfab
60-66 Nut
As long as you get a '69-'72 frame it will all go together relatively easy. The '67's and '68's use oddball springs, but you could work around that by changing the spring hangers to the FGB52's and a first gen shackle flip from DIY4X.
Old 10-16-2009, 05:32 PM   #4
Devil Pup
Devil Pup's Avatar
awesome thanks guys. now the trouble is to find the frame lol. . hey bhoeger70 do you have any pics of the swap from before and after with the height and the stance of the truck?
Old 10-16-2009, 06:36 PM   #5
OrrieG
OrrieG's Avatar
72 4x4 frame is boise $100 (not mine)
http://boise.craigslist.org/pts/1415536087.html
Old 10-16-2009, 09:48 PM   #6
Devil Pup
Devil Pup's Avatar
Only prob is i need like the full suspension i cant have it sittin i gotta swap it quick lol. but that is a pretty sweet deal
Old 10-17-2009, 10:28 AM   #7
bhoeger70
bhoeger70's Avatar
I have some pics just need to figure out how to post them again. The truck is on a stock suspension and sits about 4 inches higher than the 2wd (the rear bumper is about knee high to me I am 6'1").
Old 10-17-2009, 11:44 AM   #8
Devil Pup
Devil Pup's Avatar
Sounds pretty nice though. what size tire are you able to run with it? i wanna put a lift and run at least a 35" maybe 37"
Old 10-17-2009, 02:36 PM   #9
bhoeger70
bhoeger70's Avatar
I dont think I could much over a 33" tire without starting to run into probelms.
Old 10-17-2009, 10:25 PM   #10
Devil Pup
Devil Pup's Avatar
Thats stock 4x4 right?
Old 10-18-2009, 08:52 AM   #11
bhoeger70
bhoeger70's Avatar
stock 71 1/2 ton 4x4.
Old 10-18-2009, 01:38 PM   #12
Devil Pup
Devil Pup's Avatar
Nice. . i want one lol
Old 10-20-2009, 01:25 PM   #13
BIGphillip79
BIGphillip79's Avatar
If you only want to fit larger tires you could probly just piece together a couple things cheaper and easier than swapping frames. Couple inches of body lift 2 or 3" will run bout a hundred bucks. Even if you can't get a complete lift kit you can get another maybe 2 or 3" from some taller front springs. A spring over axle swap in the rear will get about 4" in the back.
BIGphillip79 is offline   Reply With Quote
Old 10-20-2009, 10:43 PM   #14
skchevota
skchevota's Avatar
Why not convert your 2x to 4x with the 2x frame. If you want to lift it any way. It will be mutch easyer than a full frame swap. and if you lift it you wont be using the stock 4x springs any way. what you need it a DYoffroad b52 kit, that will be all your mounts. and also one of ther engine cross member kits. then a pair of stock 52" springs. a front axle, preferabley with disk brakes. and a u bolt kit. You can do a shakel flip in the rear or just add blocks. you can keep the 2wd steering box and do a cross over steering , or swap to a 4x box. and then sorce a t case. This is the best rout IMO unless you hve a doner 4x4 that is all ready to go. Other wise even if you find a 4x4 frame and axles, you will need to add your lift, and go through the axles, and then still swap the body, engine, and tranny.
skchevota is offline   Reply With Quote
