10-05-2009, 05:57 PM | #26 |
low n' slo
Re: Project 67 DRGNWGN - 67 Burban!!
no inner fenders, and prob dont plan on running any. but if i do i will just custom make some. i do plan on taking both lower and uppers off to blast and paint them
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
10-06-2009, 11:44 AM | #27 |
Nice build, I wish I was man enough to deal with the weather... I got my suburban 2 months ago, and it's still parked... I have acquired an engine for it though. Again, nice build!!
10-09-2009, 10:07 AM | #28 |
Sofa King Crazy!!
Hey Kev, glad to see you got a thread started! I want a burb now.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
10-15-2009, 11:25 PM | #29 |
Sofa King Crazy!!
Hey Kev! Those black powdercoated emblems look great! The burb looks cool in the weeds! Swing by the shop when ya have some extra time.
10-26-2009, 05:39 PM | #30 |
low n' slo
damn here goes my build thread, i forgot about it for a little bit lol. ya david, those emblems do look good on there man, thanks for powder coating them for me. im still saving up some more $$ to get my drop spindles and to pay someone to recess some cups in my lca's. i finally got the damn air bag fitting hole drilled, i bought another step bit from lowes ($50, ouch) because i broke the 2 from harbor freight lol. i had to rotate the bag and redrill all my holes because the bolt was to close to the side of the frame and i couldnt tighten it up lol. but i finally got one side done, and when it stops raining i should knock out the other side. this side should only take a day or 2 since i know what im doin now lol. also got my fittings in today except the "t" fittings, so maybe i can start plumbing everything in november..
10-26-2009, 05:44 PM | #31 |
low n' slo
heres what my holes ended up lookin like, lol. the top and bottom holes were the 1st 2 i drilled for the bag bolts, and the 1 on the far left was the fitting hole. so i clocked the bag, and the left and right holes are now the bag bolt holes, and the one on top i widened open for my fitting. i switched out the bolts to 1 1/2 " instead of 2" and they still seem to long. maybe get some 1" ones i guess, but that seems too small..
this is why i had to clock the bag... [IMG][/IMG] heres the new holes.. [IMG][/IMG]
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 10-26-2009 at 05:45 PM. |
10-26-2009, 06:14 PM | #32 |
nice progress man, i figured id subscribe over here too
1967 c-10-built smallblock, backed by m-21, lowered 2005 silverado-tint, exhaust, lift, 35's 1964 c-10 shortbed project |
10-26-2009, 08:28 PM | #33 |
VA72C10
I am going to put washers with lock washers on the bolts...maybe that would make up the difference...
Looking for a 67-72 swb or blazer project in or around VA. |
10-26-2009, 08:41 PM | #34 |
low n' slo
i do have the lock washers in, and 1 huge fender washer for each one, its just not in that picture. when it stops raining over here ill snap a picture and see whats really keeping it from bolting all the way up. i really thought 1 1/2" should be just right...i think i seen 1 1/4" too so maybe ill try those
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 10-26-2009 at 08:42 PM. |
10-26-2009, 10:55 PM | #35 |
VA72C10
Let me know because I have 1 1/2"...I am pretty sure I checked with the lower bolt and it went in around 1"...add the thickness of the frame/spring mount/ and the two washers and 1 1/2 should be perfect???
10-28-2009, 11:12 PM | #36 |
low n' slo
heres a pic i took today of the passenger bag showing the bolts.
[IMG][/IMG] it was kinda hard getting in there to take a pic because it was wet today, let me know if you need any more.
10-28-2009, 11:51 PM | #37 |
VA72C10
Weird, did you try it off the truck and see how far they stuck up when completely screwed in? That's what everyone has recommended is the 1 1/2"....I guess 1 1/4 is the way to go???
10-29-2009, 09:34 PM | #38 |
low n' slo
no i havent but i can. ill try tomorrow after work. i was hoping to get the driver side done today but its still raining down here
10-30-2009, 12:13 AM | #39 |
Texas Big Wig
When you cup ur LCAs, dont go as deep as my first set, they hung down & drug the ground
They were 3" deep What I like better is plating the bottom of the LCAs then cut the hole & drop in some 8" pipe then weld it all up Cant wait to see it down man |
10-31-2009, 11:28 AM | #40 |
low n' slo
you mean plate it up from underneath, drop the pipe in, measure the top to sit flush and cut the rest off then weld it in?
10-31-2009, 11:49 AM | #41 |
Grandpa in the rustmobile...
looks sweet!
did it already have disc brakes on it?..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
10-31-2009, 08:24 PM | #42 |
low n' slo
ya it came like that...
finally got some work done today. pulled apart the driver side and got the 2 top bag bolts holes drilled...hopefully I can get the airbag fitting hole tomorrow before football starts. ill post some pics later tonight
11-07-2009, 12:21 PM | #43 |
low n' slo
well, i thought i had it all done untill i started bolting up the u bolt...i didnt tighten the bags yet, but when i jacked up the trailing arm and put in the u bolt, my bag kinda leaned and now doesnt sit flat up against the frame. are my holes off or something?
i guess my little orange template i made wasnt perfect lol.. [IMG][/IMG] [IMG][/IMG]
11-07-2009, 01:56 PM | #44 |
looks like you need to either tighten the bag bolts down or get some shorter ones
11-07-2009, 04:17 PM | #45 |
low n' slo
i def need shorter ones, but i just widened one of the bolt holes and sits flush now. before i ran my airline to the t fitting, it looked like bag deflated crooked...but now i ran them and aired it up and down it looks straight. im gonna wash up then snap some pics...
11-07-2009, 05:52 PM | #46 |
low n' slo
heres some pics..
driver bag deflated rear aired up rear dump
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] Last edited by kev2809; 11-07-2009 at 05:52 PM. |
11-07-2009, 05:56 PM | #47 |
low n' slo
rear dump, front up
front all up all up all down on the full lift pics, they might go a little higher, but i get nervous on putting more air in. my gauges arent hooked up and i dont wanna blow a bag lol
11-07-2009, 08:24 PM | #48 |
you gonna go lower than that
11-07-2009, 09:04 PM | #49 |
low n' slo
definitely. I still need drop spindles and recessed cups in my lca's. for the rear I still need drop blocks and to notch the frame...still a lot of work to do!
11-16-2009, 03:35 PM | #50 |
hey you can't cheat like that! letting the air out of the back tire to make it look lower... sheeeesh. ha ha ha. you got a load of work ahead of you. great progress so far!
69' 1/2 ton LONGBED__ _______ |__\__ |__(O)______(O)] My build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=354115 |
