Disconnecting fuel lines?
I've got the tank dropped about 4" and the fuel lines are still connected. How do I get them disconnected? There are four of them.
Well , I've decided to just take the bed off! I'm afraid to drop the tank any farther to get at fuel lines. They're tight as it is.
I got a few friends coming over and I went ahead and took the bed bolts off. There is one that is spinning in the hole. How can I get this out? |
#3 | |
Under construction!
I had that happen and I ended up cutting the bolt in half. ![]()
2001 Silverado bagged on 22's. *Sold* |
Where exactly did you cut it at? And what did you use to cut it?
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
OK, finally got everything changed out and hooked up. I turn key and hear the lil pump working!
