Old 10-16-2009, 12:31 PM   #1
1lowdiesel
1lowdiesel's Avatar
question about patch panels...
ok i'm a little confused about the patch panels i need and the proper names for them.
my rear floor support under the cab is rotted out along with the cab supports. i know the inner rockers i need and some other stuff but the support things are screwing me all up.
Tri Pro offers a rear cab support and also a rear cab floor support. i'm thinking the rear cab floor support is obviously under the corners of the floor that streach from the cab mount to the rockers.
BUT what is the cab support?
THEN they have a '67-'72 C/K CAB FLOOR OUTER REAR SECTION W/ BACKING PLATE, LH / RH
ahhh all these choices
look at this pic... i need the rear support that runs across the back of the cab.. but what is it called.
69 4wd V6 20k orig miles!!
05 ccsb 2wd Diesel 500hp bagged and soon to be stock floored.
01 rcsb chevy 2wd 6bt cummins :devil:> build
xtremediesel.com
1lowdiesel is offline   Reply With Quote
Old 10-16-2009, 01:41 PM   #2
StingRay
StingRay's Avatar
Re: question about patch panels...
Simplify it and buy the one piece floor with all of the supports and braces and new set of rockers. You may also need A and B pillar lower patches. I have done it by piecing it all together and on a truck that rusty I'd choose the one piece if I was doing it again
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 10-16-2009, 02:37 PM   #3
1lowdiesel
1lowdiesel's Avatar
i hear ya there. if i was building a full resto i would do it that way.
but most of the floor is in decent shape w/ the exception of the back sill, cab corners, supports and rockers. that stuff is fairly easy to fix or replace.
oh and a whole new floor is $400 bucks and WAAAY more time to put it in.
xtremediesel.com
Old 10-16-2009, 02:58 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
From what I see you need on the right side:
The rear cab support OE style. Yours is missing
The Cab outer floor section that includes the backer
The rear pillar panel
Cab CornerFront door pillar
Foot well
OE style rocker
Front cab support OE style
And possibly
Cab Floor brace
Cab Floor pan
Rear Floor cross member
You will have to fab up some sheet metal for the rear area of the corner floor. That section only comes with a complete floor.
Old 10-16-2009, 03:25 PM   #5
1lowdiesel
1lowdiesel's Avatar
cool that's what i was looking for. most of that stuff i can fab up though. the rockers and cab corners i have already too. mostly the odd shaped stuff i will have to buy but i know now what i need. thanks a bunch dave!!!
xtremediesel.com
