Old 10-16-2009, 03:59 PM   #1
cmart
cmart's Avatar
P0171 DTC - sys too lean (Bank 1)
1999 Chevy 5.3L Auto with 150,000 or so miles. I've noticed it missing a little for a while and just figured it was time to do plugs and wires, so I wasn't too worried about. The check engine light is starting to come on and it will go off after a while. I finally got my hands on a scan tool when the light was on and it showed the P0171 code.
I know that this can mean a vacuum leak, MAF dirty or bad, fuel filter dirty, etc. My question is...what do you all think I should address first in trying to figure it out. Is there one thing that outweighs the rest when it comes to this?
Any information would be appreciated. Thanks in advance.
Cory
1999 Chevrolet Silverado 1500 extended cab, short bed. 5.3L automatic.
cmart is offline   Reply With Quote
Old 10-20-2009, 01:26 PM   #2
cmart
cmart's Avatar
Re: P0171 DTC - sys too lean (Bank 1)
No one has any information/advice?
Old 10-20-2009, 05:13 PM   #3
cableguy0
chances are its the very common intake gasket issue or cracked intake. dorman makes a replacement intake the fixes the issue. did it start out as a slight quiver now and then in the idle and get worse from there?? if so chances are you need an intake and gaskets. Your well overdue for replacing the intake at that mileage they rarely ever go that long.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 10-21-2009, 08:16 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
have you ever ran E85? it attacks the "rubber" on the intake gaskets.
what are your long term and short term fuel trims at both idle and 2000 RPM for both banks? I suspect that bank 2 is getting close to setting a P0174. I would also look at the missfire data stream
68C15 is offline   Reply With Quote
Old 10-21-2009, 11:35 AM   #5
cmart
cmart's Avatar
It started out as a miss...just like a faulty spark plug or wire would do. That's why I thought it just needed a tune up. It basically did it in overdrive pulling a hill or something of the sort. I would say it's a little more constant now in overdrive, but that's about the only time I see it. Sometimes when idling it runs just a little rough. Does this sound like intake issues?
Do you happen to know the dorman part number for that kit and how much they usually run? How big of a job is it to replace that?
Thank you for your help.
Old 10-21-2009, 11:37 AM   #6
cmart
cmart's Avatar
I'm going to show my ignorance here...what is E85? I haven't had the fuel trims checked. I don't have a way of doing that myself. I'm just a simple guy that can do mechanicing with normal tools. That's why I'm prodding you all for information.
Old 10-21-2009, 09:21 PM   #7
68C15
blood type; Retumbo
68C15's Avatar
these symptoms sure sound alot like the old Vortec 5.7s with sticky valve guides.
Old 10-28-2009, 08:02 PM   #8
cableguy0
heres a link. most decent auto parts stores should have them in stock.https://www.dormanproducts.com/cgi-b...tegory_list=:0 part number is 615-183 comes with gaskets etc. E85 is 85% ethanol. most regular fuel now has at least 10% ethanol as a gimmick to reduce emissions which did nothing but run up the price of corn.
Old 11-03-2009, 07:28 PM   #9
truckdude239
truckdude239's Avatar
bad intake gasket, bad o2 sensors dirty maf, vacuum leak so many things it can be
David fuller
Ase Certified Mechanic
2015 toyota Tacoma Daily
2012 Subura outback
2000 Tahoe 5.3l 420k
1999 honda accord
