Old 10-16-2009, 04:29 PM   #1
gmcdude
gmcdude's Avatar
Window install problem
While puting the 72 GMC back together, we got to the windows and window vents, what coms first ? the window or the vent, and how do you get both of the rollers in the track? Head from
gmcdude is offline   Reply With Quote
Old 10-16-2009, 04:40 PM   #2
dan42
dan42's Avatar
Re: Window install problem
Windows go in first. If you centered the track on the window (the one that it is glued to) you should be able to put the window on the rollers fairly easily.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 10-16-2009, 04:52 PM   #3
gmcdude
gmcdude's Avatar
There a peice of metal on a 72 right at the door vent conecting both panels, interfering the vent going last. My track on my window is glued in place also.
Old 10-16-2009, 05:31 PM   #4
john
member #16
john's Avatar
Once the window is on the regulator rollers you slide it all the way to the rear of the door, then the wind wing will fit. The rear vertical track comes last.
john is offline   Reply With Quote
Old 10-16-2009, 08:55 PM   #5
gmcdude
gmcdude's Avatar
thanks
