Old 10-16-2009, 06:43 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Flexplate specs
1972 c-10 with a 350...
153 or 168 tooth?
11.5 or 10.75 Converter bolt pattern?
Mainly need to know the bolt pattern because I am looking at torque converters, and I want to make sure it will work with my flexplate.
The B&M ones I'm looking at say "This torque converter requires a small bolt pattern flexplate or dual pattern flexplate for installation."
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 10-17-2009, 09:28 AM   #2
toddtheodd
toddtheodd's Avatar
Re: Flexplate specs
Nobody knows?
IIOY???
Old 10-17-2009, 11:14 AM   #3
kwmech
Re: Flexplate specs
It should have the 168 tooth with the starter having the staggered bolt pattern (easiest way to tell). The plate should have the dual pattern then
Old 10-17-2009, 02:05 PM   #4
toddtheodd
toddtheodd's Avatar
Re: Flexplate specs
So the factory plate has a dual pattern?
IIOY???
Old 10-17-2009, 02:27 PM   #5
toddtheodd
toddtheodd's Avatar
Re: Flexplate specs
I found a picture of my flex plate. The red circled holes are the ones I used with my torque converter... are the unused holes the other bolt pattern?
IIOY???
Old 10-17-2009, 08:10 PM   #6
pumpkin
pumpkin's Avatar
Re: Flexplate specs
Yes if they are on a different bolt circle. If they are on the same bolt circle as the three u used then it would be for a six bolt torque converter.
pumpkin is offline   Reply With Quote
Old 10-17-2009, 10:12 PM   #7
toddtheodd
toddtheodd's Avatar
Re: Flexplate specs
Oh good!!!
So my B&M torque converter will work without me having to get a different flexplate.
IIOY???
