Old 10-16-2009, 09:21 PM   #1
trenz68
Damage Inc
trenz68's Avatar
Which oil pan for LS swap
Doing a ls motor swap on my 68 and since its bagged the regular truck oil pan hits the ground. I wanted to get a cts-v oil pan cause they are the smallest but are on national back order.
05 CC- magnacharged,LTs,Gt-2 cam,3.73s,tru-trac,tuned-sold
01 ECSB- caddy-clipped,22/24 intros,cammed,layin-frame
04 RCSB-joe gibbs clone,22in billets
68 stepper build
http://67-72chevytrucks.com/vboard/s...d.php?t=332337
trenz68 is offline   Reply With Quote
Old 10-16-2009, 09:30 PM   #2
short-t
short-t's Avatar
Re: Which oil pan for LS swap
Try ebay, thats where I found mine, you could also try posting a wtb add over at LS1 Tech http://www.ls1tech.com/forums/
Good luck!
short-t is offline   Reply With Quote
Old 10-16-2009, 09:34 PM   #3
trenz68
Damage Inc
trenz68's Avatar
Good luck!
Yeah that was my first place i posted...maybe an f body pan will work
68 stepper build
Old 10-16-2009, 10:36 PM   #4
Ackattack
Ackattack's Avatar
I'm using an F-body oil pan for mine. My engine came with a corvette pan (definite no go) and the truck pan hung too low for my tastes
Ackattack is offline   Reply With Quote
Old 10-17-2009, 10:15 AM   #5
Hart_Rod
Hart_Rod's Avatar
What motor mounts are you using?
Hart_Rod is offline   Reply With Quote
Old 10-17-2009, 01:23 PM   #6
Arad68
Trucks N Tranzams
Arad68's Avatar
I am going to use an F-body pan.
You might try these guys
http://www.brphotrods.com/Cadillac%2...20engines.html
or maybe this pan although it still may hang down to far.
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 10-17-2009, 06:26 PM   #7
trenz68
Damage Inc
trenz68's Avatar
ordered the tubular ones from performance online and billet adapter plates from car shop inc.
68 stepper build
Old 10-17-2009, 07:24 PM   #8
Hart_Rod
Hart_Rod's Avatar
The FBody pan should work with those mounts, but it won't work with the ECE mounts.
Old 10-17-2009, 07:28 PM   #9
trenz68
Damage Inc
trenz68's Avatar
for some reason its on back order at the dealer..to many ls swaps?
68 stepper build
Old 10-17-2009, 08:04 PM   #10
Hart_Rod
Hart_Rod's Avatar
I used the CTsV pan in my suburban. It worked out great. Check this link for pictures:
http://67-72chevytrucks.com/vboard/s...=272174&page=2
Old 10-17-2009, 08:16 PM   #11
Kel's 72 GMC
GM made with FORD paint
Kel's 72 GMC's Avatar
try a gto oil pan from 04-06
1972 GMC Custom 1500, 2WD LWB, 1970 chevy impala SS 350 c.i., shaved door handles, Ford Paint (portofino blue), blue underglow, and much more.
1998 GMC Sierra 1500 ext. cab, 2WD SWB, 305 c.i. all original 165,000 miles and still strong (daily driver)
Kel's 72 GMC is offline   Reply With Quote
Old 10-18-2009, 01:25 PM   #12
Arad68
Trucks N Tranzams
Arad68's Avatar
Try this thread at the S10 forum. It shows all of the pans for LS engines. The GTO pan is a front sump pan and will not clear the crossmember.
http://www.s10forum.com/forum/f213/l...f-them-324366/
Don
'56 Chevy 4WD SWB
95 Kia (Wifes car)
Old 10-18-2009, 01:36 PM   #13
toddtheodd
The oddest Todd around
toddtheodd's Avatar
No... just too much financial problems for the Big 3... Still.
My Chevy dealership used to have all sorts of stuff I needed, but now it's like a ghost town in there.
"The greatest pleasure is to vanquish your enemies and chase them before you, to rob them of their wealth and see those dear to them bathed in tears, to ride their horses and clasp to your bosom their wives and daughters." Ghengis Khan
IIOY???
toddtheodd is offline   Reply With Quote
Old 10-18-2009, 10:02 PM   #14
mike nutt
69fatmotor
mike nutt's Avatar
try this http://www.jegs.com/webapp/wcs/store...m=809-19212593
mike nutt is offline   Reply With Quote
Old 10-18-2009, 10:57 PM   #15
72WHITELIGHTNING
Will that one from GM Performance that's in the Jeg's catalog work??
72WHITELIGHTNING is offline   Reply With Quote
Old 10-18-2009, 11:56 PM   #16
1moretoy
i have a 01 f body ls1 in my 70 with s&p motor plates the stock pan fits perfect.
1moretoy is offline   Reply With Quote
Old 10-19-2009, 12:05 AM   #17
Rokcrln
Rokcrln's Avatar
If the one from GM/Jegs will work with a DropMember than I will need to order one right up. That price is much better than others I have seen as well.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 10-19-2009, 12:09 AM   #18
trenz68
Damage Inc
trenz68's Avatar
Kevin
LFD Inc.
i agree..you will be dragging a regular truck oil pan for sure
68 stepper build
Old 10-19-2009, 05:52 AM   #19
mike nutt
69fatmotor
mike nutt's Avatar
here's the measurement http://www.jegs.com/i/GM+Performance...12593/10002/-1 you'll have to scoll down in the window to see the measurements. the pan should fit about any installation.
Old 10-20-2009, 11:13 AM   #20
72WHITELIGHTNING
I picked up an F body oil pan. But what or whose motor mounts should I use??
Old 10-20-2009, 11:45 AM   #21
Custom 68
Custom 68's Avatar
I built all my own mounts but I am cheap... plus I did this swap 3+ years ago before it was all the rage and there was not as much available. I am using a f-body pan, I had a truck on on but like you said it hung too low for my tastes. You will need the pickup tube and baffles for the correct pan.
good luck
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 10-20-2009, 05:11 PM   #22
Robert Paul Thomas
1967 C-10 SWB LS-6 T-56
I have a F body one in my 67, fits good, but had to cut and tig a new lower face on the pan. Scaled a set of S&P mounts out of classic truck, and made a set out of 3/8 6061 aluminum. If you don't cut the pan, it may hit the passenger side of the front crossmember.
Robert Paul Thomas is offline   Reply With Quote
Old 10-21-2009, 10:51 AM   #23
Shon
If one wanted to run dry sump set up I have the Moroso pan, some of the lines and pump that came off an ASA LSx car. It is an incomplete set up but CHEAP.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
