Old 10-17-2009, 12:45 PM   #1
noonzor
mustang II front suspensions.....
so i know a few guys are running the fatman kits and really like them. just curious what other people are running and how they like theirs.
69 c10 Shortbox Build
http://67-72chevytrucks.com/vboard/s...d.php?t=360622
noonzor is offline   Reply With Quote
Old 10-17-2009, 03:12 PM   #2
Shane
Shane's Avatar
Re: mustang II front suspensions.....
What advantage does a MII bring to our trucks?
Shane is offline   Reply With Quote
Old 10-17-2009, 04:12 PM   #3
stunna
alot of gus one here run a "dropmember" which is like what your talking about. They are made by a boardmember/vendor on this site. The name is porterbuilt streetrods. There is tons of info about the product, just do a search for dropmember.
stunna is offline   Reply With Quote
Old 10-17-2009, 10:08 PM   #4
texastrendz
what advantages does it not bring?
texastrendz is offline   Reply With Quote
Old 10-18-2009, 01:16 AM   #5
SCOTI
SCOTI's Avatar
  • Smaller disc brakes: 11" brakes (that's 1" smaller than direct swap stock truck disc brakes) are considered an 'upgrade' on most basic MII kits.
  • They require non truck parts (meaning parts already on the truck cannot be re-used).
  • Many 'cheaper', budget friendly kits are weld-in only. Bolt-in kits are equal or more in total cost vs. current 'kits' that can re-use some of the truck stuff currently on the truck.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-18-2009, 09:32 AM   #6
LONGHAIR
Plus there is the fact that the MII suspension was designed for a small car with a 4cylinder engine and more than 1000lbs less total weight.
Personally, I have never been a fan of that front suspension set-up under any kind of big car either. By the time you "up-grade" everything, the cost has gotten a litte crazy too.
The money would be much better spent on the stock suspension.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 10-18-2009, 11:08 AM   #7
texastrendz
All good points, i was just wondering mostly on the rack side of it. seems like you eliminate alot of linkage when using rack and pinion. I guess that is why porterbuilt is so successful with his kit. keeps all the truck stuff and gets rid of all the linkage.
Old 10-18-2009, 11:26 AM   #8
SCOTI
SCOTI's Avatar
Exactly.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-20-2009, 06:40 AM   #9
andrewmp6
If you don't care about handling or a smooth ride on rough roads then get one.I would keep what you got get better a arms.Flaming river has a rack and pinion kit for the 73-87 trucks you might be able to make it work with yours.Or i think porterbuilt c4 member you can use coilovers on.
