Old 04-14-2003, 04:30 PM   #1
oldsub86
Question ignition switch
Can you pull the key out with the motor running? I assume something is worn in my ignition switch as I have discovered that I can. Are the switches readily available?
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 04-14-2003, 04:57 PM   #2
Hutch
Hutch's Avatar
Yes,
Yours is not broken.
It works that way by design.
Theyswitches are available, I beleive the tumbler is separate item from the switch. your door locks and ignition will be different if you just change the tumbler in the ignition.
There are kits out there which have doors,ignition and glove box keys all keyed the same.
Even the replacements will allow the key to be removed while the motor is running.
Others feel free to correct me if I am wrong on this line of thought.
Have fun
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 04-15-2003, 12:18 AM   #3
Joachim
Carolina Cajun
Smile
What Hutch said. Mine works that way also. Found out by accident when my fingers got tangled in the keys. Just slipped out. Scared the you know what outta me. Tried again later on purpose with no problems. Now I am just careful not to have too heavy of a set of keys attached. Matched sets of door/glove box/ignition are available from most major catalog retailers.
Drive happy.
Joe
The Carolina Cajun, almost famous in North Carolina since 1989!
Driving a 68 & Restoring a 66.
Lookin' for Rochester Manual 1bbl & 2bbl carbs!!
Concord, NC & Ponchatoula, LA
Joachim is offline   Reply With Quote
Old 04-15-2003, 12:53 AM   #4
StingRay
StingRay's Avatar
They only come out when the key is worn out. If you take a new key as in original condition it will not come out unless the ignition switch is in the off position. It can actually be dangerouse to not have a way to turn off your engine in a hurry but I will admit it is darn handy to be able to take the key out sometimes.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
