10-17-2009, 04:44 PM | #1 |
question on bagged front end
Do you guys have to air up the front end quite a bit to clear the fender wells on a turn? I have the Cool ride kit up front and yesterday was the first day I drove it in 3 months (took a while to get everything installed) and I had to jack the front end up to 110psi to clear 20's.
10-17-2009, 10:52 PM | #2 |
Happy to be here
Re: question on bagged front end
Tell us more about your set up. What year truck, what size 20's, dropped spindles, etc.
10-18-2009, 03:54 AM | #3 |
It is an 84 with belltech drop spindles and the full cool ride front suspension upper and lower strong arms, their bags and shocks. The rims are Helo Skids with 275/45/20. And I belive they are 20x9.
10-18-2009, 06:13 AM | #4 |
Your front tire is almost 30 inches you may need a smaller front tire
70 SWB STEPSIDE 70 BLAZER 09 challenger |
10-18-2009, 07:44 AM | #5 |
67-72 parts collector,…
Got any pics?
That 110psi is also raising the weight of the engine. I have Slam Specialties RE-7 bags on the front of my blazer. I ususally have to air up to about 100 psi just to get the front up high enough,... but then I drive it at a lower pressure. (80 psi). I have 245/40-20's up front.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 10-18-2009 at 07:46 AM. |
10-18-2009, 09:35 AM | #6 | |
I put 255-40's on my static dropped 74 (3" spindles, 1-coil cut) & I could barely move down the road as it was constantly buzzing the tops of the inner fenderwells. They're 28" tall. If you're set on that rolling stock combo & size, you're going to need to do some inner fenderwell surgery.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 10-18-2009 at 09:36 AM. |
10-18-2009, 10:37 AM | #7 |
Happy to be here
For point of referrence I have the same set up on my 77 with a 245/40/20. I can cruise at 65 psi and ride at 80-84 psi.
10-19-2009, 12:02 AM | #8 |
Thanks! I thought the tires might have been a bit big when I got the rims and tires. They were used and a steal with tires for 250. I will just have to save up for lower profile tires later on.
