Old 10-17-2009, 10:01 PM   #1
chrislehr
Engine n00b
chrislehr's Avatar
truck died on me tonight
looking for t-shooting ideas for the morning.
350, HEI distrib. I gassed it before warmed up and had a pop and it died and wouldnt refire (and typically does fine)
when I first had the engine put in, this happened once and it was a bad distrib wire.. unfortunately, im a computer guy not a mechanic, so I am not sure where to start. Im planning on packing a small toolbox and heading over in the morning...
chrislehr is offline   Reply With Quote
Old 10-18-2009, 01:15 AM   #2
jkeady
jkeady's Avatar
Re: truck died on me tonight
Pull off your distributor cap, make a note of where the distributor rotor is pointing, get in the truck and bump the starter a couple of times, then go back and see if the distributor rotor moved. I'm guessing it hasn't, which means: broken distributor gear roll pin, or broken timing chain.
Josh
'70 Custom Camper / 20
jkeady is offline   Reply With Quote
Old 10-18-2009, 05:52 AM   #3
cdowns
cdowns's Avatar
a common hei problem is the modules get fried especially if the original ruck wiring was used// unhook the wire to dizzy and turn the key on and use volt meter to see hoif theres voltage to that wire if so how much?
Old 10-18-2009, 09:36 AM   #4
chrislehr
Engine n00b
chrislehr's Avatar
Also - this is a Skip White HEI, and if it IS the second time it's a bad connection at the distro wire, I think it might be time to say goodbye.
Old 10-18-2009, 10:24 AM   #5
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Had a module die more than once my self. There is no warning. It works then it doesen't.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 10-18-2009, 02:08 PM   #6
bigguy69
dazed and confused
bigguy69's Avatar
i had this happen once. i ended up running a new to the dist. and it works fine now.
members met: redbaron69, billsbowtie,nc67
bigguy69 is offline   Reply With Quote
Old 10-18-2009, 03:03 PM   #7
chrislehr
Engine n00b
chrislehr's Avatar
Im electrical and starting system retarded.. I put a voltmeter on the red wire going into the HEI (that comes from the starter, right?) and "tried" to ground the other (may have been a poor ground) and got 0.00 there.
I tried to remove the cap - I got to the ignition module inside, but couldnt find how to get further than that.
Old 10-18-2009, 03:27 PM   #8
Hawker7
Power for HEI shouldn't come from the starter. Ideally should be a 10 gauge wire (with inline fuse) run directly from the ign unfused terminal on the fuse block.
Hawker7 is offline   Reply With Quote
Old 10-18-2009, 03:30 PM   #9
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
Was the key in the "run" position when you tried to get a voltage reading? There should only be one wire running to the dist.
Also, I had a backfire one time through the carb and it made my choke stuck shut thus making it not want to start because it was flooded. Make sure your choke is working freely.
I think you can pull the module out and have it tested at most local parts stores.
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 10-18-2009, 03:53 PM   #10
Beefcake
this happened to me
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 10-19-2009, 02:17 AM   #11
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
FWIW, about a month ago I was driving my 70 home and it was like somebody switched off my ignition. After the engine cooled down it ran OK so I limped home. I was running a 82 Chev pickup HEI. I talked to some knowledgeable automotive friends and they said it's the module in the HEI. Bought a new MSD "Streetfire" HEI and installed it. So far everything's OK.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 10-19-2009, 08:26 PM   #12
chrislehr
Engine n00b
chrislehr's Avatar
Well, if there is an inline fuse, I don't see it!
I didn't trace the cable, just went into a harness that appeared to head that away. The fusebox - so there should NOT be a fuse there then.. how silly - whats the point?
Old 10-19-2009, 09:19 PM   #13
cdowns
cdowns's Avatar
if you feed wire to the hei is coming from the original factory harness THAT'S A PROBLEMyou r not getting full voltage to the dizzy the low voltage will burn modules up on a regular basis due to the low voltage
Old 10-19-2009, 09:22 PM   #14
coloradosean2009
coloradosean2009's Avatar
I don't see why there would be no fuse. I am thinking that you need a fuse.
__________________________________________
Sean
1972 C20
2005 4Runner
coloradosean2009 is offline   Reply With Quote
Old 10-19-2009, 09:27 PM   #15
Sinister
Between Trucks...
Sinister's Avatar
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 10-20-2009, 08:52 AM   #16
DZL1
One day.....
DZL1's Avatar
So is it safe to assume that the power should come from the battery? Just wanting clarification.
DZL1.
DZL1 is offline   Reply With Quote
Old 10-20-2009, 08:56 AM   #17
cdowns
cdowns's Avatar
DZL1.
no the power needs to come from a switched power source// any doubts check the FAQ section on how to properly install an hei dizzy
Old 10-20-2009, 09:13 AM   #18
faribran
what CDOWNS said.... good place to start
faribran is offline   Reply With Quote
Old 10-20-2009, 09:29 AM   #19
67chevemall
67chevemall's Avatar
two wires there if he has a tach.
Toss the old espestis wire and run a brand new one with a fuse.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
