#451 |
Re: project INCREDIBLE HULK 6.2L with 6L80E
My money is on PB products.
#452 |
#453 |
Still Learning
I like the oil drain/fill in the rear diff. I always wondered how people put the grease in them. Keep the pics coming
#454 |
got the bridge made for the rear c-notches.... i made it outta 1.5" DOM with a 3/16" wall...made a little bend in the middle on both, cut to length, welded on...also made a "killer2" logo to match the front PB dropmember logo...
#455 |
Sunburst C10!!!
Gage 1967 C10 Shortbed Stepside |
#456 |
Killer work man
#457 |
LAME! You still milking this project!??? Didnt you build the last truck in like 5 or 6 months? Slacker
![]() Last edited by ChevyChad; 10-29-2009 at 11:48 PM. |
#458 | |
![]() ![]() and the most recent parts that rolled in were some PB trailing arm kit, with a "k2" logo (killer 2) ![]() ![]() ![]() ![]() ![]() |
#459 |
mmmmm peanut butter
#460 |
Still Learning
Nice Progress! keep it up.
#461 |
got the missing rod ends for the PB TAs, and installed everything...which leads to a problem, the "killer2" logo i made to go across the bridge, hits the rear end when aired out...so it'll have to be cut out and moved up about 1"..
#462 |
VA72C10
![]() Join Date: Mar 2008
Chassis is looking sweet.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#463 |
That's looks good how low,,
How much is that set up ..... for the rear |
#464 |
Grandpa in the rustmobile...
great work you are amazing
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#465 |
False Lies
i LOVE the build! keep up the good work!
Kyle (Steemin) Ehman -1979 Chevy CCLB, 6.7L Cummins swap - Project "RAMERADO" -2015 Yukon XL Denali (Family ride) -1977 Chevy stepside, carb'ed vortec 350 (SOLD) -Father of three daughters who will also have something cool... |
#466 |
welp after installing the PB rear suspension, the added drop put the rear end at a crazy bad angle...so the rear end was pulled out, mounting pads cut off, set proper pinion angle at ride height, and weld them back on.... also the shocks bottomed out before the bags were fully compressed (also do to the added drop of the PB arms)... so the old shock mounts were removed, new ones made, and installed on the bridge....now with the taken care of, since the 6L80E is so big and the new PB setup, we're gonna have to tunnel the cab (all this will be hidden under the center console), and make the hoop bigger on the PB crossmember.. ill get pics of that when the time comes...
#467 |
VA72C10
Nice work, I hate doing things twice but when you're going custom it happens sometimes...especially when you step up to the newest and best components...going to be an awesome truck!
#468 |
You do nice work D.. that's good you check all that stuff some folks just set it up and that's that ....
#469 |
Happy to be here
![]() Join Date: Mar 2000
You are doing an awesome job on the build. Have you considered having the Nathan cut the logo in the bridge plate too.
I don't see what you have done being on the same quality level as the rest of your build.
#470 |
WOW Off the hizzhook! Can't wait to see it done.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#471 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
Quick question pertaining to the rear setup- At full dump, how far is the frame off the ground?
Great looking build. I've been sitting on the sidelines watching this for quite some time now. You do amazing work.
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
#472 |
big guy
Thanks so much for letting me see your work! It has helped me out a great deal.
Thanks Ray |
#473 |
got some brakes in.... they are massive, 14.5" rotors all round, 4 piston polished alumnium brembo style calipers, and braided brake lines....also got another electric style master cyliner/power booster....
the calipers are 12" long and nearly 7" wide, and they look BIG, as well as the ROTORS themselves....everything installed with no problems, except the rears....the rear caliper mounting bracket mounting holes were off by .25"....im gonna call the company (abspowerbrake.com) and let them know, so they'll send me the correct brackets...but here is how big they are, and them mounted on the truck with 22s and 20s ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by 68 short step; 11-26-2009 at 01:30 AM. |
#474 |
![]() Last edited by 68 short step; 11-26-2009 at 01:42 AM. |
#475 |
GEARHEAD
Just a little bigger and you wouldn't need the wheels and tires.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 ![]() 72 ![]() HG's Plow Truck '78 ![]() Bigass Farm Truck HG's thread of miscellaneous stuff |
