Old 10-18-2009, 07:24 PM   #1
sider68
sider68's Avatar
Power Parts Needed
How do I get a list of parts I need to switch to power brakes and power steering?
I have a 56 chev on a 79 van frame. 6 bolt,drum brakes and std steering.
I also need to switch out the B7M quick shifter for a normal one. Truck has a turbo 350 auto transmission.
Thank you
sider68 is offline   Reply With Quote
Old 10-18-2009, 07:43 PM   #2
OrrieG
OrrieG's Avatar
Re: Power Parts Needed
Is the van frame based on a truck frame or big car? Usually the conversion requires new spindles, caliper brackets if not on spindle, discs, calipers, master cylinder, booster, proportion valve and lines. I would think the 79 would have come with front disc brakes. You usually have to change the front lines to the brakes too. If you are lucky it is based on a truck and you can just find one close to the years and get everything from one rig.
Power steering usually requires a PS box. Sometimes they also have different linkage than the manual. You will also need the ps pump, brackets and hoses. Steering column may be different to, doesn't the van seat and steering sit farther forward on the frame? Seems like an odd donor.
Old 10-18-2009, 11:51 PM   #3
sider68
sider68's Avatar
im just going by what the last owner said. It seems the frame is from a Van. It still has all drum brakes and 6 bolt rims
Old 10-25-2009, 08:55 PM   #4
sider68
sider68's Avatar
I goofed its the rear end and transmission that are from a 79 Chev van
Old 10-25-2009, 09:28 PM   #5
OKGMC4
OKGMC4's Avatar
There are kits out there that have every part you'd need to put power steering and/or discs on the stock axle, but given the cost wouldn't it be easier to get an IFS setup and ditch the I beam? Then you'd have power steering, disc brakes, sit lower, ride better, and be a whole lot lighter. There are several factory front clip options, mustangII kits, Corvette IFS, etc.
OKGMC4 is offline   Reply With Quote
Old 10-27-2009, 12:41 AM   #6
sider68
sider68's Avatar
I was looking at keeping the six bolt system. I cant do the work myself so I was hoping to just get parts and pay for labour to set it all up.
Old 10-27-2009, 07:07 AM   #7
OKGMC4
OKGMC4's Avatar
Gotcha...try this address
http://www.classicperform.com/4754chevtrk.html
They have a 6 lug disc upgrade kit part number 4954CBK6 and more than one type of power steering add on kit. Kits are nice - less fabrication and parts hunting. They are a bit pricey though. Hope that helps.
Old 10-27-2009, 09:27 AM   #8
mbgmike
We sell a kit to do it. We can put together a kit as you want or we are dealers for MPBrakes and others. PM us or email us.
mbgmike is offline   Reply With Quote
Old 10-28-2009, 11:54 PM   #9
sider68
sider68's Avatar
PM me the details then. Power drum brakes would still be better than what I have,correct?
