#801 |
283 Drama Queen
![]() Join Date: Dec 2004
Re: The 283 Rebuild Begins
.....and....
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
#802 |
283 Drama Queen
.....more.....(bottom one also shows newly mounted tool box)
#803 |
283 Drama Queen
...and....(newly mounted spare tire and hardware).
#804 |
283 Drama Queen
and finally.....the other side of the spare hardware and Sister Henna (Dude, you promised to take me for a walk today.)
#805 |
![]() Join Date: Mar 2008
Thanks for those awesome pictures Mac!!! I really appreciate it! !
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
#806 |
283 Drama Queen
#807 |
btw does it look like it hooks up with the standard brackets or is it a fab job?
Dig the classic license plate!
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it Last edited by 1964C10; 10-21-2009 at 04:47 PM. |
#808 |
283 Drama Queen
Standard - all the way, same same - long time.
![]() On the plate - I'm going to redo the yellow with a roller next time, because masking sucks and my hand isn't steady enough to freehand with a brush.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. Last edited by MacAttack; 10-21-2009 at 04:51 PM. |
#809 | |
you just need a good brush and keep a wet edge on it(the brush) and it will flow just fine ron |
#810 |
283 Drama Queen
Well - I have a shaky hand and I like it that way, but that's another story.
#811 |
Shloooooong bed member #2
I just can't beleive we got some pictures from you Mac....
![]() ![]() Is that the original spare tire holder?
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q Last edited by 4dranch; 10-22-2009 at 11:01 AM. |
#812 | |
283 Drama Queen
Yeah - I know, I'm driving everybody nuts with my new Sony. ![]() I have no idea on the spare tire cross-beam. It came with the truck. When the idiots took my truck, apparently they drove up over a boulder or an engine block, because that bar and the hanging hardware was shoved up under the differential. Had to cut all that stuff off the frame and recreate it with bolts, couplers and all-thread. I got the lock bracket from Classic Industries, which is kind of a POS, but it's functional. That and a outdoor Master Lock and it was ready for the road. Mac. ![]()
#813 |
Thanks again Mac! Did those plates come with your truck or did you get them off ebay?
#814 |
Sunburst C10!!!
lookin good
cant believe we got pictures out of you
Gage 1967 C10 Shortbed Stepside |
#815 | |
283 Drama Queen
Mac. ![]()
#816 |
283 Drama Queen
Thanks Gage, the new camera is alot of fun.
#817 | |
#818 |
283 Drama Queen
Hey - my thread just cleared 20k views!
#819 |
HOW long until spring??
![]() Join Date: Mar 2009
Outstanding work! I would give you rep points for that!!!
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#820 |
283 Drama Queen
![]() Without the brake pedal applied – the stop lights blink of and on and I can hear the signal canister “pinging” under the dash. Apparently, it’s been doing this from getting the truck back from the shop – weeks ago. I tried switching the canister out with a new one – same / same. If that’s not odd enough, sometimes (other than when I put the brake on) it stops on its own. Has no effect on the tail or front parking lights, but turn signal sticks on – when I apply the brakes. Tried everyone’s ideas on my alternator wackiness, but nothing is working. Still not a single amp of charging and nothing showing on the dash gage. Truck runs fine – but still having to use the trickle charger to be able to drive the rig around. Mac. ![]()
#821 |
turn signals and brake lights have their one circuit different from the taillights
grounding problem? ron |
#822 |
hey Mac they didn't pull your wire did they?
if they did the screw driver nbr on the column they may have buggered some of the wires in there. did they pull any off under the dash> ron . do you have the later str column with the 4 way flashers Last edited by padresag; 11-16-2009 at 02:03 PM. |
#823 |
283 Drama Queen
They butchered the steering column and the wiring therein, in some drug induced attempt to get their 3-speed linkage to function.
The column was/is bone stock, for an automatic - but it was so tore up I had to take what was left of the original shifter off, plug and paint over the hole and put a Gennie shifter on the floor. I replaced the turn-signal canceling unit and wiring (with the horn ring hardware) with all new stuff and my transmission place plugged that into the stock plug, further down the column. The really good news is - I just called my old-school auto electrician and he's closed up shop and retired. Mac. ![]()
#824 |
283 Drama Queen
![]() Went by my old guy to see if he was actually gone - he was. Bummer. New possibility seems like he knows what he's doing, has a 66' Chevy P/U and because of my scheduling issues - can't drop my truck off until Monday (11/23). He's open at 6AM which is kind if unusual and really cool. I'll make him a hit list and we'll see how he does. Mac. ![]()
#825 |
Are you using the hazard flasher or just the turn signals? I just went through all that wiring nonsense on my 64 when I adapted a newer tilt column into my 64 . I can walk you through the colors codes- let me find the wiring diagram and I'll post it. The brake switch over-rides the 4-way flasher and just holds all lamps steady on . Hey my electricians license is handy to have sometimes. Yell if you need help.
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 11-16-2009 at 07:17 PM. Reason: additional post |
