Old 10-22-2009, 07:15 PM   #1
chevyjr73
chevyjr73's Avatar
engine question about my 86 c10
why is it that i cannot find a crate engine listed for my 1986 c10 305 carbureted engine? all i can find listed is up to an 85 and then from 87 on up, everywhere i have checked bypasses the 86 model year. my stock engine has just about had it and i was trying to figure out which way to go. thanks for all of your help.
chevyjr73 is offline   Reply With Quote
Old 10-22-2009, 07:36 PM   #2
ont_guy_38
ont_guy_38's Avatar
Re: engine question about my 86 c10
85 would be the same as your 86
ont_guy_38 is offline   Reply With Quote
Old 10-22-2009, 07:49 PM   #3
fiddy9apache
fiddy9apache's Avatar
any reason you want a crate engine? why not have a local rebuilder rebuild a 350 and replace the 305.
fiddy9apache is offline   Reply With Quote
Old 10-22-2009, 08:23 PM   #4
pcmcobra
pcmcobra's Avatar
go with a 5.3 or 6.0
you will be happy!
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 11-03-2009, 07:30 AM   #5
HOGDADDY
HOGDADDY's Avatar
Get a Goodrench 350 from Chevy they are cheap and a decent motor.
HOGDADDY is offline   Reply With Quote
Old 11-03-2009, 10:46 AM   #6
knockretard
I would go with this one
https://store.gmperformanceparts.com...-12499529--%3E
it's the "replace all" engine from GM.
There is also a 260h.p. version in the GM performance parts catalog. It has a roller cam, and replaces 70-85 engines. The part# for that engine is 10067353.
knockretard is offline   Reply With Quote
Old 11-03-2009, 12:22 PM   #7
Damien
Damien's Avatar
The reason you are having trouble with a direct application is the '86 was the first year of the 1 piece rear main and the last year the intake bolts were all at the same angle. The The 2 piece rear main seal used through '85 uses a different oil pan and flex plate then the 1 piece. The '87 up will either need an intake for the '87 and newer heads or sloting of the center two bolt holes on each side of an old style intake. Any small block will work, you just need to have the correct parts.
I can still count my vehicles on two... wait three hands.
Damien is offline   Reply With Quote
